IPS_GetObject
array IPS_GetObject (int $ObjectID)
ObjectID | The ID of the object |
The following information are available as key => value pairs:
Index | Type | Description |
ChildrenIDs | array | Object IDs of the children. See: IPS_GetChildrenIDs |
HasChildren | boolean | TRUE if the object has child objects. See: IPS_HasChildren |
ObjectID | integer | ID of the object |
ObjectIcon | string | File name of the icon without extension. See: IPS_SetIcon |
ObjectIdent | string | Identifier of the Object. See: IPS_SetIdent |
ObjectInfo | string | Description that can be provided by the user. See: IPS_SetInfo |
ObjectIsDisabled (since 4.0) | boolean | TRUE if the object is disabled. See IPS_SetDisabled |
ObjectIsHidden | boolean | TRUE if the object is hidden in the visualization. See IPS_SetHidden |
ObjectIsReadOnly | boolean | TRUE if the object is read-only. (Currently only used for state variables) |
ObjectName | string | Name of the Object. See: IPS_SetName |
ObjectPosition | integer | Position of the object in the visualization. This value may not be unique. See: IPS_SetPosition |
ObjectType | integer | Type of the object (0: Category, 1: Instance, 2: Variable, 3: Script, 4: Event, 5: Media, 6: Link) |
ObjectSummary | string | Short description of an object, which is generated by the module if needed |
ParentID | integer | Parent object. 0 = No parent object. See: IPS_SetParent |
This function returns an array containing information about the object with the ID ObjectID. If the object is not available, an alert is generated.
print_r(IPS_GetObject(19668));
/* returns, e.g.,:
Array
[ParentID] => 26691
[ObjectID] => 43502
[ObjectType] => 1
[ObjectIdent] =>
[ObjectName] => MX FESLIM (ID: 1)
[ObjectInfo] => This is a device instance
[ObjectIcon] => IPS
[ObjectSummary] =>
[ObjectPosition] => 1
[ObjectIsReadOnly] =>
[ObjectIsHidden] =>
[ObjectIsDisabled] =>
[ObjectIsLocked] =>
[HasChildren] => 1
[ChildrenIDs] => Array
[0] => 43430
[1] => 55892
[2] => 36597
[3] => 18993
[4] => 34524
[5] => 12269
[6] => 44450
[7] => 23394
[8] => 11693
[9] => 13654
