IPS_SetPosition
Require: IP-Symcon >= 2.1
boolean IPS_SetPosition (int $ObjectID, int $Position)
ObjectID | The ID of the object |
Position | Position value |
This function assigns the position value Position to the object with the ID ObjectID. The position will be used to display the objects in the desired order. The default value is 0. The position value may not be unique. If two positions are equal, the objects are primarily sorted by type. For equal types, the name is used as secondary sorting criterion.
IPS_SetPosition(47381, 5);
