IPS_SetDisabled
Require: Symcon >= 4.0
 bool IPS_SetDisabled (int $ObjectID, bool $Disabled)
ObjectID
The ID of the object
Disabled
TRUE if the object should be disabled; FALSE if it should be enabled
This function sets the object with the ID ObjectID to disabled, i.e., it may be visible in the visualizations but it is not clickable or usable.
IPS_SetDisabled(47381, true); // The object becomes disabled
