IPS_SetIcon
Require: IP-Symcon >= 2.1
 boolean IPS_SetIcon (int $ObjectID, string $Icon)
ObjectID
The ID of the object
Icon
Filename of the icon without path and extension
This function assigns an icon to the object with the ID ObjectID. The name of the icon is the filename without the extension or path.
A list of available icons can be found under Icons
IPS_SetIcon(47381, "weather");
