IPS_GetEvent
Require: Symcon >= 3.1
array IPS_GetEvent (int $EventID)
| EventID | ID of the event |
The following information are available as key => value pairs:
| CyclicDateType | integer | Date type. See IPS_SetEventCyclic |
| CyclicDateValue | integer | Date interval. See IPS_SetEventCyclic |
| CyclicDateDay | integer | Day of date. See IPS_SetEventCyclic |
| CyclicDateDayValue | integer | Day of date, interval. See IPS_SetEventCyclic |
| CyclicDateFrom | array | Unix Timestamp of the start day of the event, 0 = Always. See IPS_SetEventCyclicDateBounds |
| CyclicDateTo | array | Unix Timestamp of final day of the event, 0 = Never. See IPS_SetEventCyclicDateBounds |
| CyclicTimeType | integer | Time type. See IPS_SetEventCyclic |
| CyclicTimeValue | integer | Time interval. See IPS_SetEventCyclic |
| CyclicTimeFrom | array | Unix Timestamp of the start time for the event, 0 = Midnight. See IPS_SetEventCyclicTimeBounds |
| CyclicTimeTo | array | Unix timestamp of the end time for the event, 0 = Midnight. See IPS_SetEventCyclicTimeBounds |
| EventActionID | string | ID of the executed Action |
| EventActionParameters | array | Parameter of the executed Action |
| EventConditions | array | Array of conditions. See IPS_SetEventCondition and IPS_SetEventConditionRule |
| EventID | integer | ID of the event |
| EventLimit | integer | Remaining number of executions. 0 = No Limit |
| EventScript | string | Always an empty string, since this field is only present for compatibility reasons. The execution is always controlled via the action, which is configured via IPS_SetEventScheduleAction. |
| EventActive | boolean | TRUE if the event is active |
| EventType | integer | Event Type: (0: trigger 1: cyclic 2: schedule) |
| LastRun | float | Unix timestamp of the last run, 0 = Never |
| NextRun | float | Unix timestamp of the next run, 0 = Never |
| LastActionID | integer | Action ID from the weekly schedule of the last execution, 0 = No action was executed |
| NextActionID | integer | Action ID from the weekly schedule for the next execution, 0 = No action will be executed next time |
| ScheduleActions | array | Array of actions of the schedule. See IPS_SetEventScheduleActionEx |
| ScheduleGroups | array | Array of groups with switch points of the schedule. See IPS_SetEventScheduleGroup and IPS_SetEventScheduleGroupPoint |
| TriggerSubsequentExecution | boolean | Allow to run again in triggering without value change |
| TriggerType | integer | Value for the trigger type: See IPS_SetEventTrigger |
| TriggerValue | variant | Value that is used for the trigger check, depending on the used trigger type |
| TriggerVariableID | integer | VariableID to be used as a trigger |
The command returns an array containing information about the event with the ID EventID.
Since IP-Symcon 3.1, the fields CyclicDateFrom, CyclicDateTo, CyclicTimeFrom, and CyclicTimeTo are arrays. If you need compatibility with version 3.0 and older, you can use the IPS_GetEventCompatibility function available since IP-Symcon 3.1, which restores the old functionality.
LastActionID/NextActionID have been available since version 8.1
$EventID = 46413;
$EventInfo = IPS_GetEvent($EventID);
print_r($EventInfo);
/* returns e.g.:
Array
[EventID] => 41227
[EventType] => 2
[EventActive] => 1
[EventLimit] => 0
[EventConditions] => Array
[0] => Array
[ID] => 0
[ParentID] => 0
[VariableRules] => Array
[0] => Array
[ID] => 1
[VariableID] => 29025
[Comparison] => 4
[Value] => 500
[DateRules] => Array
[0] => Array
[ID] => 0
[Comparison] => 0
[Value] => Array
[Day] => 8
[Month] => 8
[Year] => 2001
[1] => Array(3)
[ID] => 1
[Comparison] => 4
[Value] => Array
[Day] => 1
[Month] => 1
[Year] => 2021
[TimeRules] => Array
[0] => Array
[ID] => 1
[Comparison] => 3
[Value] => Array
[Hour] => 9
[Minute] => 0
[Second] => 0
[1] => Array
[ID] => 2
[Comparison] => 5
[Value] => Array
[Hour] => 17
[Minute] => 0
[Second] => 0
[DayOfTheWeekRules] => Array
[0] => Array
[ID] => 0
[Comparison] => 0
[Value] => 3
[Operation] => 1
[TriggerType] => 0
[TriggerVariableID] => 0
[TriggerValue] =>
[TriggerSubsequentExecution] =>
[CyclicDateType] => 0
[CyclicDateValue] => 0
[CyclicDateDay] => 0
[CyclicDateDayValue] => 0
[CyclicDateFrom] => Array
[Day] => 0
[Month] => 0
[Year] => 0
[CyclicDateTo] => Array
[Day] => 0
[Month] => 0
[Year] => 0
[CyclicTimeType] => 0
[CyclicTimeValue] => 0
[CyclicTimeFrom] => Array
[Hour] => 0
[Minute] => 0
[Second] => 0
[CyclicTimeTo] => Array
[Hour] => 0
[Minute] => 0
[Second] => 0
[ScheduleActions] => Array
[0] => Array
[ID] => 0
[Name] => Kalt
[Color] => 255
[ScriptText] =>
[ActionID] => {3644F802-C152-464A-868A-242C2A3DEC5C}
[ActionParameters] => Array
[VALUE] => 2
[1] => Array
[ID] => 1
[Name] => Warm
[Color] => 16711680
[ScriptText] =>
[VALUE] => 0
[ScheduleGroups] => Array
[0] => Array
[ID] => 0
[Days] => 127
[Points] => Array
[0] => Array
[ID] => 13
[Start] => Array
[Hour] => 0
[Minute] => 0
[Second] => 0
[ActionID] => 1
[1] => Array
[ID] => 14
[Start] => Array
[Hour] => 12
[Minute] => 0
[Second] => 0
[ActionID] => 0
[EventScript] =>
[LastRun] => 0
[NextRun] => 0
[LastActionID] => 0
[NextActionID] => 0
