IPS_SetEventScheduleGroupPoint
Require: Symcon >= 3.2
bool IPS_SetEventScheduleGroupPoint (int $EventID, int $GroupID, int $PointID, int $StartHour, int $StartMinute, int $StartSecond, int $ActionID)
| EventID | ID of the event to be changed |
| GroupID | ID of the group the switch point belongs to. The group must already exist. |
| PointID | Unique ID for this switch point. IDs only need to be unique for this group. |
| StartHour | Start hour (0..23) |
| StartMinute | Start minute (0..59) |
| StartSecond | Start second (0..59) |
| ActionID | ID of the schedule action which should be executed at the start time. The ID needs to be valid. |
This function sets the switch point with the start time according to StartHour, StartMinute, and StartSecond and the ID PointID to the group with the ID GroupID of a schedule event with the ID EventID.
If StartHour, StartMinute, or StartSecond are outside of the valid range (StartHour < 0 or > 23, StartMinute < 0 or > 59, StartSecond < 0 or > 59, e.g., -1), the switch point with the given PointID is deleted. If no switch point with this ID exists, an error is raised.
Within a group, only a single switch point may have the same combination of StartHour, StartMinute, and StartSecond.
//Create switch points for the group with ID 0 (= Mo - Fr)
IPS_SetEventScheduleGroupPoint($EventID, 0, 0, 8, 0, 0, 1); //Call action with ID 1 (=Warm) at 8:00:00
IPS_SetEventScheduleGroupPoint($EventID, 0, 1, 22, 30, 0, 3); //Call action with ID 3 (=Eco) at 22:30:00
//Delete switch point with ID 1 from group with ID 0 (= Mo - Fr)
IPS_SetEventScheduleGroupPoint($EventID, 0, 1, -1, -1, -1, 1);
