IPS_SetEventTrigger
 boolean IPS_SetEventTrigger (int $EventID, int $TriggerType, int $TriggerVariableID)
EventID
ID of the event to be changed
TriggerType
Value Description
0 On Variable Update
1 On Variable Change
2 On Limit Exceed - Value is determined by IPS_SetEventTriggerValue
3 On Limit Drop - Value is determined by IPS_SetEventTriggerValue
4 On specific Value - Value is determined by IPS_SetEventTriggerValue
TriggerVariableID
VariableID on whose change or update should be responded
This command configures a triggering event. It defines the observed variable TriggerVariableID and which TriggerType the event should react to.
IPS_SetEventTrigger($EventID, 0, 12345);  //OnUpdate for variable 12345
