IPS_SetEventCyclic
boolean IPS_SetEventCyclic (int $EventID, int $DateType, int $DateInterval, int $DateDay, int $DateDayInterval, int $TimeType, int $TimeInterval)
EventID |
ID of the event to be changed |
DateType |
Value |
Description |
0 |
No date type. Daily execution. |
1 |
Once. IPS_SetEventCyclicDateBounds for target date |
2 |
Daily |
3 |
Weekly |
4 |
Monthly |
5 |
Annually |
DateInterval |
Value |
Description |
0 |
0 (No Evaluation) |
1 |
0 (No Evaluation) |
2 |
Every X days |
3 |
Every X weeks |
4 |
Every X months |
5 |
1 = January ... 12 = December |
DateDay |
Value |
Description |
0 |
0 (No Evaluation) |
1 |
0 (No Evaluation) |
2 |
0 (No Evaluation) |
3 |
see table: Daily values (desired daily values must be added) |
4 |
see table: Daily values, 0 for every Xth day of the month |
5 |
0 (No Evaluation) |
Table: Daily values
Day |
Value |
Monday |
1 |
Tuesday |
2 |
Wednesday |
4 |
Thursday |
8 |
Friday |
16 |
Saturday |
32 |
Sunday |
64 |
DateDayInterval |
Value |
Description |
0 |
0 (No Evaluation) |
1 |
0 (No Evaluation) |
2 |
0 (No Evaluation) |
3 |
0 (No Evaluation) |
4 |
Every Xth DateDay of the month or every Xth day of the month if DateDay = 0 |
5 |
Every Xth day of the specified month |
TimeType |
TimeInterval |
Value |
Description |
0 |
0 (No Evaluation) |
1 |
Every X seconds |
2 |
Every X minutes |
3 |
Every X hours |
The configuration of a cyclic event determines in which intervals the event should run. This includes a DateInterval that specifies the interval in a day, week, month, or year rhythm and a time interval that defines second, minute, or hour-based intervals for each day.
If the DateInterval "week" is selected, it is possible to determine the days of the week on which the event should be started. For an annual or monthly DateInterval, the day of the month / year can be specified with the parameter DateValue. For all other types the parameter is not used and can simply be set to the placeholder 0.
Remarks:
- (Monthly) In the variant "On the Xth day every Y months", choosing X > 31 signals that the event is run on the last day of every month. When choosing X = 31, the event only triggers in months with 31 days.
- (Monthly) In the variant "On the Xth weekday every Y months", choosing X > 5 signals that the event is run on the last defined weekday of every month. Choosing X = 5 can lead to an event not being run, as, e.g., not every month includes a 5th Friday.
- (Annually) In the variant "The Xth day of a specific month", a timer is executed only if X is a valid day in the month, otherwise the timer is not running. The special case of the 29th February is not supported.
IPS_SetEventCyclic($eid, 2, 1, 0, 0, 3, 6); //Every day all 6 hours
IPS_SetEventCyclic($eid, 0, 0, 0, 2, 2 ,2); //Every 2 minutes
IPS_SetEventCyclic($eid, 3, 2, 1+4, 0, 0, 0); //Every 2 weeks at Monday+Wednesday
IPS_SetEventCyclicTimeBounds($eid, mktime(15, 0, 0), 0); //always at 3 pm
