VoIP_SendDTMF
Require: IP-Symcon >= 5.3
boolean VoIP_SendDTMF (int $InstanceID, int $ConnectionID, string $DTMF)
ConnectionID | ID of the connection to be switched |
DTMF | Characters to be sent as DTMF |
Sends the characters DTMF on the connection with the ID ConnectionID on the VoIP instance with the ID InstanceID.
Only these characters are allowed: 0-9, *, #
// Sends the DTMF signals for "*123#" on the connection with ID 3
VoIP_SendDTMF(12345, 3, "*123#");
