VoIP_GetConnection
Require: IP-Symcon >= 5.2
 array VoIP_GetConnection (int $InstanceID, int $ConnectionID)
ConnectionID
ID of the connection to be switched
Array with the following information
Field Data type Description
ID integer ConnectionID
TimeStamp integer Time stamp of the call
Number string Number with which a connection was established
Direction integer Call direction: 0 = Incoming call, 1 = Outgoing call
Connected boolean Connection status: FALSE = not connected, TRUE = connected
Disconnected boolean Disconnection status: FALSE = not disconnected, TRUE = disconnected
Returns the information of the connection with ID ConnectionID of the VoIP instance with ID InstanceID.
---return---
// Returns information of the connection with ID 3.
print_r(VoIP_GetConnection(12345, 3));
// Sample output:
Array
    [ID] => 3
    [TimeStamp] => 1566915689
    [Number] => 045130500511
    [Data] =>
    [Direction] => 1
    [Connected] => 1
    [Disconnected] =>
