Device list
Supported Gateways
Product Description
EnOcean LAN Gateway (TCM310/TCM515 LAN Gateway)
Product information
IP Gateway
BSC-BOR USB Gateway
EnOcean USB300 USB Gateway
EnOcean Pi Raspberry Pi plug-in board
EnOcean FGW14 (with FAM14) USB/serial Gateway (operating mode 6) and
Radio extension FAM14 (operating mode 2)
FAM USB USB Gateway (must be entered as TCM 130)
TCM130 All devices that support the ESP2 protocol
TCM310 All devices that support the ESP3 protocol (Dolphin)
TCM515 All devices that support the ESP3 protocol (Dolphin)
Thermokon STC-Ethernet IP Gateway
Supported Devices
The following devices have been examined for their compatibility with IP-Symcon.
On request we will be happy to check other devices that are not listed.
General
Product Description
PTM 200 Button/Expert
PTM 200 Switch
RCM 1xx Switching actuator (universal)
STM100 Sensor
STM250 Sensor
alphaEOS
Product Description
Drive B2 Radio actuator
SENSE TF-H Indoor climate sensor (temperature and humidity)
Eltako
Product Description EEP number (See EEP list below)
DSZ14DRS Wireless single-phase energy meter transmitter module EEP: A5-12-01
DSZ14WDRS Wireless single-phase energy meter transmitter module EEP: A5-12-01
F2L14 RS485 bus actuator 2-stage ventilation relay stand-alone module
F3Z14D RS485 bus electricity meter collector EEP: A5-12-01
F4HK14 4-channel heating-cooling relay stand-alone module
F4T65 Wireless sensors without batteries or wires EEP: F6-02-01
FABH65S Outdoor motion/brightness sensor stand-alone module
FADS60-230V Wireless actuator for outdoor twilight sensor stand-alone module
FAE14LPR Individual room control heating/cooling for 2 zones stand-alone module
FAE14SSR Individual room control heating/cooling for 2 zones with solid-state relays stand-alone module
FAFT60 Outdoor humidity temperature sensor stand-alone module
FAH60 Outdoor brightness sensor stand-alone module
FAH60B Outdoor brightness sensor stand-alone module,
EEP: A5-06-01
FAH63 Outdoor brightness sensor stand-alone module
FAH65S Outdoor brightness sensor stand-alone module
FASM60 Wireless outdoor transmitter module EEP: F6-02-01
FBH65B Motion/brightness sensor stand-alone module
FBH65S Motion/brightness sensor stand-alone module
FBH65TFB Motion/brightness sensor stand-alone module
FCO2TF65 CO2 sensor EEP: A5-09-04
FD62NP-230V Wireless universal dimming actuator without N-connection stand-alone module
FD62NPN-230V Wireless universal dimming actuator stand-alone module
FFR14 RS485 bus actuator field release switch stand-alone module
FFR61-230V Field release switch stand-alone module
FHF Wireless sensor window handle EEP: F6-10-00
FHK14 Wireless actuator for heating/cooling relays stand-alone module
FHK61SSR-230V Wireless actuator for heating/cooling relays stand-alone module
FHK61U-230V Wireless actuator for heating relay stand-alone module
FIFT65S Indoor humidity temperature sensor stand-alone module
FIH65S Outdoor brightness sensor stand-alone module
FIH65Bv Indoor brightness sensor EEP: A5-06-02
FJ62/12-36V DC Wireless blind and roller shutter actuator stand-alone module
FJ62NP-230V Wireless blind and roller shutter actuator stand-alone module
FKC Wireless card switch stand-alone module
FKF Wireless card switch stand-alone module
FL62-230V Wireless light actuator 10A/250V AC stand-alone module
FL62NP-230V Wireless light actuator 10A/250V AC stand-alone module
FLC61-230V Wireless light controller stand-alone module
FMS14 RS485 bus actuator multifunction impulse switching relay stand-alone module
FMS61NP-230V Wireless actuator multifunction impulse switch stand-alone module
FMZ14 RS485 bus actuator multifunction time relay stand-alone module
FMZ61-230V Wireless actuator multifunction time relay stand-alone module
FR62-230V Wireless relay actuator 10 A/250 V AC stand-alone module
FR62NP-230V Wireless relay actuator 10 A/250 V AC stand-alone module
FRGBW71L Dimming actuator stand-alone module
FRW Wireless sensor smoke alarm device stand-alone module
FSB14 Actuator for shading elements and roller shutters stand-alone module
FSB61 Wireless actuator for shading elements and roller shutters stand-alone module
FSB71 Wireless actuator for shading elements and roller shutters stand-alone module
FSDG14 Wireless single-phase energy meter transmitter module EEP: A5-12-01
FSG14/1-10V Dimming actuator stand-alone module
FSG71/1-10V Dimming actuator stand-alone module
FSM14 Radio transmitter module EEP: F6-02-01
FSM60B 4-channel input EEP: A5-30-03
FSM61 Wireless 2-way transmitter module EEP: F6-01-01
FSR14SSR RS485 bus actuator 2-channel impulse switching relay noiseless stand-alone module
FSR14-2x RS485 bus actuator 2-channel impulse switching relay stand-alone module
FSR14-4x RS485 bus actuator 4-channel impulse switching relay stand-alone module
FSR61-230V Wireless actuator for impulse switching relays stand-alone module
FSR61/8-24V Wireless actuator for impulse switching relays stand-alone module
FSR61LN-230V Wireless actuator for impulse switching relays stand-alone module
FSR61NP-230V Wireless actuator for impulse switching relays stand-alone module
FSR61VA Wireless single-phase energy meter transmitter module EEP: A5-12-01
FSR61VA-10A Wireless actuator for 10A impulse switching relays stand-alone module
FSR71 Wireless actuator for 2-channel impulse switching relays stand-alone module
FSS12 Wireless electricity meter transmitter module EEP: A5-12-01
FSSA-230V Wireless actuator socket switch actuator stand-alone module
FSU14 RS485 bus display timer EEP: A5-13-04
FSU65D Wireless sensor timer with display EEP: F6-01-01
FSUD-230V Dimming actuator stand-alone module
FSVA-230V Wireless single-phase energy meter transmitter module EEP: A5-12-01
FT-FTSB Tip wireless humidity/temperature sensor EEP: A5-04-02
FT4F Wireless sensor surface wireless pushbutton EEP: F6-02-01
FT55 Wireless sensor surface wireless pushbutton EEP: F6-02-01
FTF65S Temperature sensor EEP: A5-02-05
FTK Wireless window/door contact EEP: D5-00-01
FTKB Wireless window/door contact EEP: D5-00-01
FTKE Wireless window/door contact EEP: F6-10-00
FTN14 RS485 bus actuator staircase lighting overrun switch stand-alone module
FTN61NP-230V Wireless actuator for staircase lighting overrun switch stand-alone module
FTR65DS Wireless sensor temperature controller stand-alone module
FTR65HS Wireless sensor temperature controller stand-alone module
FTR78S Wireless temperature controller with rotary knob EEP: A5-10-03
FUD14 Dimming actuator stand-alone module
FUD14-800W Dimming actuator stand-alone module
FUD61NP Dimming actuator stand-alone module
FUD61NPN Dimming actuator stand-alone module
FUD70S-230V Dimming actuator stand-alone module
FUD71 Dimming actuator stand-alone module
FUTH55D Wireless sensor clock thermo-hygrostat stand-alone module
FUTH65D Wireless sensor clock thermo-hygrostat stand-alone module
FWS61 Wireless weather data transmitter module EEP: A5-13-01, A5-13-02
FWWKW71L PWM Dimming actuator for LED stand-alone module
FWZ12 Wireless single-phase energy meter transmitter module EEP: A5-12-01
FWZ14 Wireless single-phase energy meter transmitter module EEP: A5-12-01
FWZ61 Wireless single-phase energy meter transmitter module EEP: A5-12-01
FZK14 RS485 bus actuator time relay for card switches/smoke alarm devices stand-alone module
FZK61NP-230V Wireless actuator for time relays with card switch/smoke alarm device stand-alone module
FZS Wireless sensor pull switch stand-alone module
FMMS44SB Wireless mini multisensor EEP: D2-14-41
Hoppe
FHF Window handle F6-10-00
SecuSignal eWindow handle Amsterdam E0400/FR-408 F69 F6-10-00
SecuSignal eWindow handle Atlanta 0530S/FR-408 100 Nm F9 F6-10-00
SecuSignal eWindow handle Toulon E0400/FR-408 F69 F6-10-00
ConnectHome eWindow handle Tokyo F6-10-00
ConnectHome eWindow handle New York F6-10-00
HORA
Product Description
SmartDrive MX Actuator
Kieback & Peter
Product Description
MD15 Small actuator
Maco
Smart Ready Sensor eTRONIC Door/window sensor EEP: A5-14-01
NodOn
ASP-2-1-00 Smart Plug EEP: D2-01-0A
ASP-2-1-01 Smart Plug Metering EEP: D2-01-0B
ASP-2-1-10 Smart Plug EEP: D2-01-0A
ASP-2-1-11 Smart Plug Metering EEP: D2-01-0B
SIN-2-1-01 In-wall Multifunction Relay Switch 1-Channel EEP: D2-01-0F
SIN-2-2-01 In-wall ON/OFF Lighting Relay Switch 2-Channel EEP: D2-01-0B
SIN-2-RS-01 Roller Shutter Relay Switch EEP: D2-05-00
OPUS
514.441 55 Wall transmitter module standard EEP: F6-02-01
561.150.9052 Temperature sensor (2 buttons) EEP: A5-10-12
561.150.9069 Temperature sensor (4 buttons) EEP: A5-10-22
563.010-C* Bridge 1 channel EEP: D2-01-01
563.014-C* Bridge 1 channel, 16A EEP: D2-01-01
563.020-C* Bridge 2 channel EEP: D2-01-11
563.031-C* Bridge roller shutter/ blind EEP: D2-05-02
563.035-C* Bridge dimmer EEP: D2-01-03
563.051-C Smart Motion Sensor (light) EEP: F6-02-01
563.052-C Smart motion sensor multifunction EEP: F6-02-01
563.053 Smart Motion Sensor Ambient Assisted Living - Inability to move EEP: A5-07-03
563.055-C Smart Motion Sensor (presence) EEP: A5-07-03
563.067-C Water alarm (instant alarm) EEP: F6-05-01
563.068-C Water alarms (source disks) EEP: A5-30-03
563.069-C Smoke alarm device EEP: F6-05-02
*Requires setup via Opus Config Tool (563.040)
PEHA
Product Description
Various All devices that support EEP
Thermokon
Product Description
SR04 Temperature/humidity
SAB02 Actuator
Thanos Room control unit
EEP
All devices that use the following EEPs are supported by IP-Symcon.
Actuators
New since version Old Description
A5-20-12 4.0 07-20-12 Temperature Controller Input
Bi-Directional
A5-20-01 4.0 07-20-01 Battery Powered Actuator
D2-01-00 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-01 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-02 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-03 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-04 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-05 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-06 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-07 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-08 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-09 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0A 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0B 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0C 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0D 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0E 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-0F 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-10 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-11 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-12 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-13 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-01-14 4.3 Electronic switches and dimmer with Energy Measurement and Local Content
D2-03-00 5.5 Light, Switching + Blind Control Type 0x00
D2-03-0A 5.5 Push Button – Single Button
D2-03-10 5.5 Mechanical Handle
D2-05-00 5.3 Blinds Control for Position/Angle Type 0x00
D2-05-01 5.3 Blinds Control for Position/Angle Type 0x01
D2-05-02 5.3 Blinds Control for Position/Angle Type 0x02
D2-06-01 4.3 Multisensor Window Handle - Alarm, Position Sensor, Vacation Mode, Optional Sensors
D2-07-00 5.5 Locking Systems Control - Mortise lock
D2-11-01 5.3 Room Operating Panel (BI-DIR) Type 0x01
D2-11-02 5.3 Room Operating Panel (BI-DIR) Type 0x02
D2-11-03 5.3 Room Operating Panel (BI-DIR) Type 0x03
D2-11-04 5.3 Room Operating Panel (BI-DIR) Type 0x04
D2-11-05 5.3 Room Operating Panel (BI-DIR) Type 0x05
D2-11-06 5.3 Room Operating Panel (BI-DIR) Type 0x06
D2-11-07 5.3 Room Operating Panel (BI-DIR) Type 0x07
D2-11-08 5.3 Room Operating Panel (BI-DIR) Type 0x08
D2-15-00 5.5 People Activity Counter
D2-A0-01 5.5 Valve Control (BI-DIR)
Sensors
A5-02-01 4.0 07-02-01 Temperature Sensor Range -40°C to 0°C
A5-02-02 4.0 07-02-02 Temperature Sensor Range -30°C to +10°C
A5-02-03 4.0 07-02-03 Temperature Sensor Range -20°C to +20°C
A5-02-04 4.0 07-02-04 Temperature Sensor Range -10°C to +30°C
A5-02-05 4.0 07-02-05 Temperature Sensor Range 0°C to +40°C
A5-02-06 4.0 07-02-06 Temperature Sensor Range +10°C to +50°C
A5-02-07 4.0 07-02-07 Temperature Sensor Range +20°C to +60°C
A5-02-08 4.0 07-02-08 Temperature Sensor Range +30°C to +70°C
A5-02-09 4.0 07-02-09 Temperature Sensor Range +40°C to +80°C
A5-02-0A 4.0 07-02-0A Temperature Sensor Range +50°C to +90°C
A5-02-0B 4.0 07-02-0B Temperature Sensor Range +60°C to +100°C
A5-02-10 4.0 07-02-10 Temperature Sensor Range -60°C to +20°C
A5-02-11 4.0 07-02-11 Temperature Sensor Range -50°C to +30°C
A5-02-12 4.0 07-02-12 Temperature Sensor Range -40°C to +40°C
A5-02-13 4.0 07-02-13 Temperature Sensor Range -30°C to +50°C
A5-02-14 4.0 07-02-14 Temperature Sensor Range -20°C to +60°C
A5-02-15 4.0 07-02-15 Temperature Sensor Range -10°C to +70°C
A5-02-16 4.0 07-02-16 Temperature Sensor Range 0°C to +80°C
A5-02-17 4.0 07-02-17 Temperature Sensor Range +10°C to +90°C
A5-02-18 4.0 07-02-18 Temperature Sensor Range +20°C to +100°C
A5-02-19 4.0 07-02-19 Temperature Sensor Range +30°C to +110°C
A5-02-1A 4.0 07-02-1A Temperature Sensor Range +40°C to +120°C
A5-02-1B 4.0 07-02-1B Temperature Sensor Range +50°C to +130°C
A5-02-20 4.0 07-02-20 10 Bit Temperature Sensor Range -10°C to +41.2°C
A5-02-30 4.0 07-02-30 10 Bit Temperature Sensor Range -40°C to +62.3°C
A5-04-01 4.0 07-04-01 Range 0°C to +40°C and 0% to 100%
A5-04-02 4.1 07-04-02 Range -20°C to +60°C and 0% to 100%
A5-04-03 4.1 07-04-03 Range -20°C to +60°C 10bit-measurement and 0% to 100%
A5-04-03 5.3 07-04-03 Temperature and Humidity Sensor
A5-06-01 4.0 07-06-01 Range 300lx to 60.000lx
A5-06-02 4.0 07-06-02 Range 0lx to 1.020lx
A5-06-03 4.0 07-06-03 10-bit measurement (1-Lux resolution) with range 0lx to 1000lx
A5-07-01 4.0 07-07-01 Occupancy with Supply voltage monitor
A5-07-01 5.3 07-07-01 gN-Deckenbewegungsmelder 360°
A5-07-01 5.3 07-07-01 Desk Occupancy
A5-07-02 4.0 07-07-02 Occupancy with Supply voltage monitor
A5-07-03 4.0 07-07-03 Occupancy with Supply voltage monitor and 10-bit illumination measurement
A5-08-01 4.0 07-08-01 Range 0lx to 510lx
A5-08-01 4.0 07-08-01 0°C to +51°C and Occupancy Button
A5-08-02 4.0 07-08-02 Range 0lx to 1020lx
A5-08-02 4.0 07-08-02 0°C to +51°C and Occupancy Button
A5-08-03 4.0 07-08-03 Range 0lx to 1530lx
A5-08-03 4.0 07-08-03 -30°C to +50°C and Occupancy Button
A5-09-01 4.0 07-09-01 CO Sensor (not in use)
A5-09-02 4.0 07-09-02 CO-Sensor 0 ppm to 1020 ppm
A5-09-04 4.0 07-09-04 CO2 Sensor
A5-09-04 5.3 07-09-04 CO2, Temperature and Humidity Sensor
A5-09-05 4.0 07-09-05 VOC Sensor
A5-09-06 4.0 07-09-06 Radon
A5-09-07 4.0 07-09-07 Particles
A5-09-08 4.0 07-09-08 Pure CO2 Sensor
A5-10-01 4.0 07-10-01 Temperature Sensor
A5-10-01 4.0 07-10-01 Set Point
A5-10-01 4.0 07-10-01 Fan Speed and Occupancy Control
A5-10-02 4.0 07-10-02 Temperature Sensor
A5-10-02 4.0 07-10-02 Set Point
A5-10-02 4.0 07-10-02 Fan Speed and Day/Night Control
A5-10-03 4.0 07-10-03 Temperature Sensor
A5-10-03 4.0 07-10-03 Set Point Control
A5-10-04 4.0 07-10-04 Temperature Sensor
A5-10-04 4.0 07-10-04 Set Point and Fan Speed Control
A5-10-05 4.0 07-10-05 Temperature Sensor
A5-10-05 4.0 07-10-05 Set Point and Occupancy Control
A5-10-06 4.0 07-10-06 Temperature Sensor
A5-10-06 4.0 07-10-06 Set Point and Day/Night Control
A5-10-07 4.0 07-10-07 Temperature Sensor
A5-10-07 4.0 07-10-07 Fan Speed Control
A5-10-08 4.0 07-10-08 Temperature Sensor
A5-10-08 4.0 07-10-08 Fan Speed and Occupancy Control
A5-10-09 4.0 07-10-09 Temperature Sensor
A5-10-09 4.0 07-10-09 Fan Speed and Day/Night Control
A5-10-0A 4.0 07-10-0A Temperature Sensor
A5-10-0A 4.0 07-10-0A Set Point Adjust and Single Input Contact
A5-10-0B 4.0 07-10-0B Temperature Sensor and Single Input Contact
A5-10-0C 4.0 07-10-0C Temperature Sensor and Occupancy Control
A5-10-0D 4.0 07-10-0D Temperature Sensor and Day/Night Control
A5-10-10 4.0 07-10-10 Temperature and Humidity Sensor
A5-10-10 4.0 07-10-10 Set Point and Occupancy Control
A5-10-11 4.0 07-10-11 Temperature and Humidity Sensor
A5-10-11 4.0 07-10-11 Set Point and Day/Night Control
A5-10-12 4.0 07-10-12 Temperature and Humidity Sensor and Set Point
A5-10-13 4.0 07-10-13 Temperature and Humidity Sensor
A5-10-13 4.0 07-10-13 Occupancy Control
A5-10-14 4.0 07-10-14 Temperature and Humidity Sensor
A5-10-14 4.0 07-10-14 Day/Night Control
A5-10-15 4.0 07-10-15 10 Bit Temperature Sensor
A5-10-15 4.0 07-10-15 6 bit Set Point Control
A5-10-16 4.0 07-10-16 10 Bit Temperature Sensor
A5-10-16 4.0 07-10-16 6 bit Set Point Control;Occupancy Control
A5-10-17 4.0 07-10-17 10 Bit Temperature Sensor
A5-10-17 4.0 07-10-17 Occupancy Control
A5-10-18 4.0 07-10-18 Illumination
A5-10-18 4.0 07-10-18 Temperature Set Point
A5-10-18 4.0 07-10-18 Temperature Sensor
A5-10-18 4.0 07-10-18 Fan Speed and Occupancy Control
A5-10-19 4.0 07-10-19 Humidity
A5-10-19 4.0 07-10-19 Temperature Set Point
A5-10-19 4.0 07-10-19 Temperature Sensor
A5-10-19 4.0 07-10-19 Fan Speed and Occupancy Control
A5-10-1A 4.0 07-10-1A Supply voltage monitor
A5-10-1A 4.0 07-10-1A Temperature Set Point
A5-10-1A 4.0 07-10-1A Temperature Sensor
A5-10-1A 4.0 07-10-1A Fan Speed and Occupancy Control
A5-10-1B 4.0 07-10-1B Supply Voltage Monitor
A5-10-1B 4.0 07-10-1B Illumination
A5-10-1B 4.0 07-10-1B Temperature Sensor
A5-10-1B 4.0 07-10-1B Fan Speed and Occupancy Control
A5-10-1C 4.0 07-10-1C Illumination
A5-10-1C 4.0 07-10-1C Illumination Set Point
A5-10-1C 4.0 07-10-1C Temperature Sensor
A5-10-1C 4.0 07-10-1C Fan Speed and Occupancy Control
A5-10-1D 4.0 07-10-1D Humidity
A5-10-1D 4.0 07-10-1D Humidity Set Point
A5-10-1D 4.0 07-10-1D Temperature Sensor
A5-10-1D 4.0 07-10-1D Fan Speed and Occupancy Control
A5-10-1E 5.5 07-10-1E Temperature Sensor, Supply Voltage, Light, Fan Speed, and Occupancy Control
A5-10-1F 4.0 07-10-1F Temperature Sensor
A5-10-1F 4.0 07-10-1F Set Point
A5-10-1F 4.0 07-10-1F Fan Speed
A5-10-1F 4.0 07-10-1F Occupancy and Unoccupancy Control
A5-10-20 4.0 07-10-20 Temperature and Set Point with Special Heating States
A5-10-21 4.0 07-10-21 Temperature
A5-10-21 4.0 07-10-21 Humidity and Set Point with Special Heating States
A5-10-22 5.5 07-10-22 Temperature Sensor, Set Point, Humidity, and Fan Speed
A5-10-23 5.5 07-10-23 Temperature Sensor, Set Point, Humidity, Fan Speed, and Occupancy Control
A5-11-01 4.0 07-11-01 Lighting Controller
A5-11-02 4.0 07-11-02 Temperature Controller Output
A5-11-03 4.0 07-11-03 Blind Status
A5-11-04 4.0 07-11-04 Extended Lighting Status
A5-12-00 4.0 07-12-00 Counter
A5-12-00 5.3 07-12-00 Operations Counting
A5-12-01 4.0 07-12-01 Electricity
A5-12-02 4.0 07-12-02 Gas
A5-12-03 4.0 07-12-03 Water
A5-13-01 4.0 07-13-01 Weather Station
A5-13-02 4.0 07-13-02 Sun Intensity
A5-13-03 4.0 07-13-03 Date Exchange
A5-13-04 4.0 07-13-04 Time and Day Exchange
A5-13-05 4.0 07-13-05 Direction Exchange
A5-14-01 4.0 07-14-01 Single Input Contact (Window/Door)
A5-14-01 4.0 07-14-01 Supply voltage monitor
A5-14-02 4.0 07-14-02 Single Input Contact (Window/Door)
A5-14-02 4.0 07-14-02 Supply voltage monitor and Illumination
A5-14-03 4.0 07-14-03 Single Input Contact (Window/Door)
A5-14-03 4.0 07-14-03 Supply voltage monitor and Vibration
A5-14-04 4.0 07-14-04 Single Input Contact (Window/Door)
A5-14-04 4.0 07-14-04 Supply voltage monitor
A5-14-04 4.0 07-14-04 Vibration and Illumination
A5-14-05 4.0 07-14-05 Vibration/Tilt
A5-14-05 4.0 07-14-05 Supply voltage monitor
A5-14-05 5.3 07-14-05 Chair Occupancy Solar Sensor
A5-14-06 4.0 07-14-06 Vibration/Tilt
A5-14-06 4.0 07-14-06 Illumination and Supply voltage monitor
A5-14-07 5.0 07-14-07 Dual door contact with States (Open/Closed/Locked/Unlocked)
A5-14-07 5.0 07-14-07 Supply voltage monitor
A5-14-08 5.0 07-14-08 Dual door contact with States (Open/Closed/Locked/Unlocked)
A5-14-08 5.0 07-14-08 Supply voltage monitor and Vibration detection
A5-14-09 5.0 07-14-09 Window/Door Sensor with States (Open/Closed/Tilt)
A5-14-09 5.0 07-14-09 Supply voltage monitor
A5-14-0A 5.0 07-14-0A Window/Door Sensor with States (Open/Closed/Tilt)
A5-14-0A 5.0 07-14-0A Supply voltage monitor and Vibration detection
A5-20-01 5.3 07-14-01 Heating Valve Controller
A5-20-06 5.5 07-20-06 Heating Valve Controller
A5-30-01 4.0 07-30-01 Single Input Contact
A5-30-01 4.0 07-30-01 Battery Monitor
A5-30-02 4.0 07-30-02 Single Input Contact
A5-30-03 4.0 07-30-03 4 Digital Inputs
A5-30-03 4.0 07-30-03 Wake and Temperature
A5-30-04 4.0 07-30-04 3 Digital Inputs
A5-30-04 4.0 07-30-04 1 Digital Input 8 Bits
A5-37-01 4.0 07-37-01 Demand Response
A5-38-08 4.0 07-38-08 Gateway
A5-38-09 4.0 07-38-09 Extended Lighting-Control
D2-14-30 6.0 Sensor for Smoke, Air quality, Hygrothermal comfort, Temperature and Humidity
D2-14-41 6.4 Sensor for Humidity, Illumination, Temperature, Dissolved oxegen, Contact, Acceleration
D2-15-00 5.4 People Activity Counter
D2-32-00 4.3 A.C. Current Clamp
D2-32-00 5.3 Single Channel CT Clamp
D2-32-01 4.3 A.C. Current Clamp
D2-32-02 4.3 A.C. Current Clamp
D5-00-01 4.0 06-00-01 Single Input Contact
D5-00-01 5.3 06-00-01 Magnet Contact
F6-01-01 5.5 05-01-01 Push Button
F6-02-01 4.0 05-02-01 Light and Blind Control - Application Style 1
F6-02-02 4.0 05-02-02 Light and Blind Control - Application Style 2
F6-02-03 4.0 05-02-03 Light Control - Application Style 1
F6-02-04 4.0 05-02-04 Light and blind control ERP2
F6-03-01 4.0 05-03-01 Light and Blind Control - Application Style 1
F6-03-02 4.0 05-03-02 Light and Blind Control - Application Style 2
F6-04-01 4.0 05-04-01 Key Card Activated Switch
F6-04-02 4.0 05-04-02 Key Card Activated Switch ERP2
F6-05-00 5.0 05-05-00 Wind Speed Threshold Detector
F6-05-01 4.0 05-05-01 Liquid Leakage Sensor (mechanic harvester)
F6-05-02 5.0 05-05-02 Smoke Detector
F6-10-00 4.1 05-10-00 Window Contact Sensor
F6-10-01 5.5 05-10-01 Window Handle ERP2
