DS2890
The DS2890 is a digital potentiometer with 8-bit resolution.
Unfortunately he is no longer manufactured. No replacement type exists.
"CHARGE PUMP CONSIDERATIONS" should be used on the 1-Wire Center 0 to 10V output. To do this, enable "Use CPC."
For a test the slider can be changed and the "SET" button can be pushed.
