IPS_GetVariableEventList
 array IPS_GetVariableEventList (int $VariableID)
VariableID
ID of the variable
List of IDs of all events associated to the variable
This function returns an array whose elements are the respective IDs of the events in which the variable with the ID VariableID is used. The events can be processed further by the command IPS_GetEvent.
$events = IPS_GetVariableEventList(12345);
print_r($events);  // determines all events of the current script
