IPS_GetMedia
 array IPS_GetMedia (int $MediaID)
MediaID
The ID of the media object
The following information are available as key => value pairs:
Index  Type Description
IsAvailable(up to 3.4) boolean TRUE if media file is available (replaced by MediaIsAvailable since version 4.0)
IsLinked(up to 3.4) boolean TRUE if the file is located outside the Media folder (removed since version 4.0)
LastUpdate(up to 3.4) float Unix timestamp of last update (replaced by MediaUpdated since version 4.0)
MediaCRC string CRC32 of the file
MediaFile string Path to the file
MediaID integer MediaID
MediaIsAvailable(since 4.0) boolean TRUE if media file is available
MediaSize integer Size in bytes
MediaType integer Media Type (0: Form 1: Image 2: Sound 3: Stream 4: Chart, 5: Document)
MediaUpdated(since 4.0) integer Unix timestamp of last update
SendEvent(up to 3.4) boolean TRUE if automatic file changes should be sent (removed since version 4.0)
The command returns an array with information about media with the ID MediaID.
(info: The previous form of the command that was used up to version 3.4 is accessible as "array IPS_GetMediaCompatibility(integer $MediaID)" since version 4.0 if the corresponding Special Switch is set. [/
// Since Version 4.0
print_r(IPS_GetMedia(45699));
/* returns e.g.:
Array
    [MediaCRC] => E2D2C1D1
    [MediaFile] => media\45699.bin
    [MediaID] => 45699
    [MediaIsAvailable] => 1
    [MediaIsCached] =>
    [MediaSize] => 8192
    [MediaType] => 0
    [MediaUpdated] => 1214421546
print_r(IPS_GetMediaCompatibility(45699));
/* returns e.g.:
Array
    [IsAvailable] => 1
    [IsLinked] =>
    [LastUpdate] => 1214421546
    [MediaID] => 45699
    [MediaSize] => 8192
    [MediaType] => 0
    [SendEvent] =>
// Up to Version 3.4
/* returns e.g.:
Array
    [IsAvailable] => 1
    [IsLinked] =>
    [MediaID] => 45699
    [MediaSize] => 8192
    [MediaType] => 0
    [SendEvent] =>
