IPS_GetLink
Require: IP-Symcon >= 2.1
 array IPS_GetLink (int $LinkID)
LinkID
ID of the link
The following information are available as key => value pairs:
Index  Type Description
LinkID integer ObjectID
LinkChildID(until 3.4) integer ID of the object with which this link is connected. See: IPS_SetLinkTargetID (since 4.0 permanently replaced by TargetID)
TargetID(since 2.6) integer ID of the object with which this link is connected. See: IPS_SetLinkTargetID
The command returns an array containing information about the link with the ID LinkID. If the link does not exist, a warning is generated.
The functionality until version 3.4 is provided with the function "array IPS_GetLinkCompatibility(integer $LinkID)" since version 4.0 and can be accessed with Special Switches.
//Since Version 4.0
print_r(IPS_GetLink(19668));
/* returns e.g.:
Array
    [LinkID] => 19668
    [TargetIDID] => 14444
print_r(IPS_GetLinkCompatibility(19668));
/* returns e.g.:
Array
    [LinkID] => 19668
    [LinkChildID] => 14444
    [TargetID] => 14444
//Up to Version 3.4
/* returns e.g.:
Array
    [LinkID] => 19668
    [TargetID] => 14444
