IPS_GetInstanceListByModuleID
 array IPS_GetInstanceListByModuleID (string $ModuleID)
ModuleID
ModuleID of the instances to be returned
An array of integer values ​​of all found IDs
The command returns all instances that match the specified ModuleID in an array.
The GUIDs are found in IPS_GetModuleList
//FS20 Transmitter
$guid = "{48FCFDC1-11A5-4309-BB0B-A0DB8042A969}";
//List
print_r(IPS_GetInstanceListByModuleID($guid));
