IPS_GetModuleList
 array IPS_GetModuleList ()
An array ​​of all the GUIDs of the modules in IP-Symcon given as strings
The command determines the IDs of all available modules in IP-Symcon. The IDs are listed in an array of strings.
print_r(IPS_GetModuleList());
/* returns e.g.:
Array
    [0] => {2D8B0172-166C-45B0-B979-61A787809E22}
    [1] => {CCC52C33-D77A-4AE9-A6CF-462F152532A0}
    [2] => {11842D31-3CA4-4F1B-BBA9-E4A0FE1873AF}
    [3] => {4CB91589-CE01-4700-906F-26320EFCF6C4}
    etc. ...
//Output of all module names with GUID
foreach(IPS_GetModuleList() as $guid)
    $module = IPS_GetModule($guid);
    // Limit modules to Core library
    if($module['LibraryID'] == "{0945206A-47AA-4FDD-9093-99051E410E82}") {
        $pair[$module['ModuleName']] = $guid;
ksort($pair);
foreach($pair as $key=>$guid)
    echo $key." = ".$guid."\n";
ALL2x = {D805EC4C-7D17-4E84-98D3-A441AA71ACA3}
ALL3690 = {BBD04875-8CC5-412A-B848-B2AB6F08C425}
ALL3691 = {07CAE61E-01FA-4086-A2D1-55C442D8C8BF}
ALL4000 = {2D8B0172-166C-45B0-B979-61A787809E22}
ALLUniversal = {FB6B8DD0-CD8E-4CE7-8613-D7BD6436720A}
Archive Control = {43192F0B-135B-4CE7-A0A7-1475603F3060}
CMI = {AAAB8DD0-CD8E-4CE7-8613-D913371701AE}
Calendar Control = {1B9A5AF2-F2D2-4827-A13D-FFA6AB350371}
Client Socket = {3CFF0FD9-E306-41DB-9B5A-9D06D38576C3}
Connect Control = {9486D575-BE8C-4ED8-B5B5-20930E26DE6F}
Cutter = {AC6C6E74-C797-40B3-BA82-F135D941D1A2}
DMX Gateway = {B1E43BF6-770A-4FD7-B4FE-6D265F93746B}
DMX Output = {E19C2E41-7347-4A3B-B7D9-A9A88E0D133E}
DMX RGB = {1AF36760-644E-4DA9-8776-01BA6DF6178E}
DNSSD Control = {780B2D48-916C-4D59-AD35-5A429B2355A5}
Dummy Module = {485D0419-BE97-4548-AA9C-C083EB82E61E}
EnOcean Configurator = {9BA823CF-83C6-4A5F-DBC2-295CA971833E}
EnOcean D20500 = {8DFBE8BC-FC2D-61F0-375C-C8C2A13CDC1A}
EnOcean D20501 = {927296DC-B74F-F0B8-2C4E-6B98236EDD94}
EnOcean D20502 = {B4D91880-71C1-626B-94D7-521565495264}
EnOcean Discovery = {29E1D618-F3CB-6868-59C6-4DCD02F8C78D}
EnOcean EEP A50201RX = {432FF87E-4497-48D6-8ED9-EE7104A50201}
EnOcean EEP A50202RX = {432FF87E-4497-48D6-8ED9-EE7104A50202}
EnOcean EEP A50203RX = {432FF87E-4497-48D6-8ED9-EE7104A50203}
EnOcean EEP A50204RX = {432FF87E-4497-48D6-8ED9-EE7104A50204}
EnOcean EEP A50205RX = {432FF87E-4497-48D6-8ED9-EE7104A50205}
EnOcean EEP A50206RX = {432FF87E-4497-48D6-8ED9-EE7104A50206}
EnOcean EEP A50207RX = {432FF87E-4497-48D6-8ED9-EE7104A50207}
EnOcean EEP A50208RX = {432FF87E-4497-48D6-8ED9-EE7104A50208}
EnOcean EEP A50209RX = {432FF87E-4497-48D6-8ED9-EE7104A50209}
EnOcean EEP A5020ARX = {432FF87E-4497-48D6-8ED9-EE7104A5020A}
EnOcean EEP A5020BRX = {432FF87E-4497-48D6-8ED9-EE7104A5020B}
EnOcean EEP A50210RX = {432FF87E-4497-48D6-8ED9-EE7104A50210}
EnOcean EEP A50211RX = {432FF87E-4497-48D6-8ED9-EE7104A50211}
EnOcean EEP A50212RX = {432FF87E-4497-48D6-8ED9-EE7104A50212}
EnOcean EEP A50213RX = {432FF87E-4497-48D6-8ED9-EE7104A50213}
EnOcean EEP A50214RX = {432FF87E-4497-48D6-8ED9-EE7104A50214}
EnOcean EEP A50215RX = {432FF87E-4497-48D6-8ED9-EE7104A50215}
EnOcean EEP A50216RX = {432FF87E-4497-48D6-8ED9-EE7104A50216}
EnOcean EEP A50217RX = {432FF87E-4497-48D6-8ED9-EE7104A50217}
EnOcean EEP A50218RX = {432FF87E-4497-48D6-8ED9-EE7104A50218}
EnOcean EEP A50219RX = {432FF87E-4497-48D6-8ED9-EE7104A50219}
EnOcean EEP A5021ARX = {432FF87E-4497-48D6-8ED9-EE7104A5021A}
EnOcean EEP A5021BRX = {432FF87E-4497-48D6-8ED9-EE7104A5021B}
EnOcean EEP A50220RX = {432FF87E-4497-48D6-8ED9-EE7104A50220}
EnOcean EEP A50230RX = {432FF87E-4497-48D6-8ED9-EE7104A50230}
EnOcean EEP A50401RX = {432FF87E-4497-48D6-8ED9-EE7104A50401}
EnOcean EEP A50402RX = {432FF87E-4497-48D6-8ED9-EE7104A50402}
EnOcean EEP A50403RX = {432FF87E-4497-48D6-8ED9-EE7104A50403}
EnOcean EEP A50601RX = {432FF87E-4497-48D6-8ED9-EE7104A50601}
EnOcean EEP A50602RX = {432FF87E-4497-48D6-8ED9-EE7104A50602}
EnOcean EEP A50603RX = {432FF87E-4497-48D6-8ED9-EE7104A50603}
EnOcean EEP A50701RX = {432FF87E-4497-48D6-8ED9-EE7104A50701}
EnOcean EEP A50702RX = {432FF87E-4497-48D6-8ED9-EE7104A50702}
EnOcean EEP A50703RX = {432FF87E-4497-48D6-8ED9-EE7104A50703}
EnOcean EEP A50801RX = {432FF87E-4497-48D6-8ED9-EE7104A50801}
EnOcean EEP A50802RX = {432FF87E-4497-48D6-8ED9-EE7104A50802}
EnOcean EEP A50803RX = {432FF87E-4497-48D6-8ED9-EE7104A50803}
EnOcean EEP A50901RX = {432FF87E-4497-48D6-8ED9-EE7104A50901}
EnOcean EEP A50902RX = {432FF87E-4497-48D6-8ED9-EE7104A50902}
EnOcean EEP A50904RX = {432FF87E-4497-48D6-8ED9-EE7104A50904}
EnOcean EEP A50905RX = {432FF87E-4497-48D6-8ED9-EE7104A50905}
EnOcean EEP A50906RX = {432FF87E-4497-48D6-8ED9-EE7104A50906}
EnOcean EEP A50907RX = {432FF87E-4497-48D6-8ED9-EE7104A50907}
EnOcean EEP A50908RX = {432FF87E-4497-48D6-8ED9-EE7104A50908}
EnOcean EEP A51001RX = {432FF87E-4497-48D6-8ED9-EE7104A51001}
EnOcean EEP A51002RX = {432FF87E-4497-48D6-8ED9-EE7104A51002}
EnOcean EEP A51003RX = {432FF87E-4497-48D6-8ED9-EE7104A51003}
EnOcean EEP A51004RX = {432FF87E-4497-48D6-8ED9-EE7104A51004}
EnOcean EEP A51005RX = {432FF87E-4497-48D6-8ED9-EE7104A51005}
EnOcean EEP A51006RX = {432FF87E-4497-48D6-8ED9-EE7104A51006}
EnOcean EEP A51007RX = {432FF87E-4497-48D6-8ED9-EE7104A51007}
EnOcean EEP A51008RX = {432FF87E-4497-48D6-8ED9-EE7104A51008}
EnOcean EEP A51009RX = {432FF87E-4497-48D6-8ED9-EE7104A51009}
EnOcean EEP A5100ARX = {432FF87E-4497-48D6-8ED9-EE7104A5100A}
EnOcean EEP A5100BRX = {432FF87E-4497-48D6-8ED9-EE7104A5100B}
EnOcean EEP A5100CRX = {432FF87E-4497-48D6-8ED9-EE7104A5100C}
EnOcean EEP A5100DRX = {432FF87E-4497-48D6-8ED9-EE7104A5100D}
EnOcean EEP A51010RX = {432FF87E-4497-48D6-8ED9-EE7104A51010}
EnOcean EEP A51011RX = {432FF87E-4497-48D6-8ED9-EE7104A51011}
EnOcean EEP A51012RX = {432FF87E-4497-48D6-8ED9-EE7104A51012}
EnOcean EEP A51013RX = {432FF87E-4497-48D6-8ED9-EE7104A51013}
EnOcean EEP A51014RX = {432FF87E-4497-48D6-8ED9-EE7104A51014}
EnOcean EEP A51015RX = {432FF87E-4497-48D6-8ED9-EE7104A51015}
EnOcean EEP A51016RX = {432FF87E-4497-48D6-8ED9-EE7104A51016}
EnOcean EEP A51017RX = {432FF87E-4497-48D6-8ED9-EE7104A51017}
EnOcean EEP A51018RX = {432FF87E-4497-48D6-8ED9-EE7104A51018}
EnOcean EEP A51019RX = {432FF87E-4497-48D6-8ED9-EE7104A51019}
EnOcean EEP A5101ARX = {432FF87E-4497-48D6-8ED9-EE7104A5101A}
EnOcean EEP A5101BRX = {432FF87E-4497-48D6-8ED9-EE7104A5101B}
EnOcean EEP A5101CRX = {432FF87E-4497-48D6-8ED9-EE7104A5101C}
EnOcean EEP A5101DRX = {432FF87E-4497-48D6-8ED9-EE7104A5101D}
EnOcean EEP A5101FRX = {432FF87E-4497-48D6-8ED9-EE7104A5101F}
EnOcean EEP A51020RX = {432FF87E-4497-48D6-8ED9-EE7104A51020}
EnOcean EEP A51021RX = {432FF87E-4497-48D6-8ED9-EE7104A51021}
EnOcean EEP A51022RX = {BBE179DE-1241-CB89-6803-492049D5546B}
EnOcean EEP A51023RX = {9880FC1A-AD89-5749-12A0-AF6C99D50B28}
EnOcean EEP A51101RX = {432FF87E-4497-48D6-8ED9-EE7104A51101}
EnOcean EEP A51102RX = {432FF87E-4497-48D6-8ED9-EE7104A51102}
EnOcean EEP A51103RX = {432FF87E-4497-48D6-8ED9-EE7104A51103}
EnOcean EEP A51104RX = {432FF87E-4497-48D6-8ED9-EE7104A51104}
EnOcean EEP A51200RX = {432FF87E-4497-48D6-8ED9-EE7104A51200}
EnOcean EEP A51201RX = {432FF87E-4497-48D6-8ED9-EE7104A51201}
EnOcean EEP A51202RX = {432FF87E-4497-48D6-8ED9-EE7104A51202}
EnOcean EEP A51203RX = {432FF87E-4497-48D6-8ED9-EE7104A51203}
EnOcean EEP A51301RX = {432FF87E-4497-48D6-8ED9-EE7104A51301}
EnOcean EEP A51302RX = {432FF87E-4497-48D6-8ED9-EE7104A51302}
EnOcean EEP A51303RX = {432FF87E-4497-48D6-8ED9-EE7104A51303}
EnOcean EEP A51304RX = {432FF87E-4497-48D6-8ED9-EE7104A51304}
EnOcean EEP A51305RX = {432FF87E-4497-48D6-8ED9-EE7104A51305}
EnOcean EEP A51401RX = {432FF87E-4497-48D6-8ED9-EE7104A51401}
EnOcean EEP A51402RX = {432FF87E-4497-48D6-8ED9-EE7104A51402}
EnOcean EEP A51403RX = {432FF87E-4497-48D6-8ED9-EE7104A51403}
EnOcean EEP A51404RX = {432FF87E-4497-48D6-8ED9-EE7104A51404}
EnOcean EEP A51405RX = {432FF87E-4497-48D6-8ED9-EE7104A51405}
EnOcean EEP A51406RX = {432FF87E-4497-48D6-8ED9-EE7104A51406}
EnOcean EEP A51407RX = {B3A8A26C-FF2F-491E-9279-E981959293C0}
EnOcean EEP A51408RX = {2C9E6E3A-319F-7ADF-024C-E8DEA7209A52}
EnOcean EEP A51409RX = {29CBDDA5-6CA6-4C17-9360-1979DCBD1E43}
EnOcean EEP A5140ARX = {1F3E63B6-F354-44FF-98DE-BEB63F36310C}
EnOcean EEP A52006 = {D25790E7-DC98-7EE3-4D74-2F0484392795}
EnOcean EEP A52012RX = {432FF87E-4497-48D6-8ED9-EE7104A52012}
EnOcean EEP A52012TX = {432FF87E-4497-48D6-8ED9-AA7104A52012}
EnOcean EEP A53001RX = {432FF87E-4497-48D6-8ED9-EE7104A53001}
EnOcean EEP A53002RX = {432FF87E-4497-48D6-8ED9-EE7104A53002}
EnOcean EEP A53003RX = {432FF87E-4497-48D6-8ED9-EE7104A53003}
EnOcean EEP A53004RX = {432FF87E-4497-48D6-8ED9-EE7104A53004}
EnOcean EEP A53701RX = {432FF87E-4497-48D6-8ED9-EE7104A53701}
EnOcean EEP A53808RX = {432FF87E-4497-48D6-8ED9-EE7104A53808}
EnOcean EEP A53809RX = {432FF87E-4497-48D6-8ED9-EE7104A53809}
EnOcean EEP D20100 = {8328F257-35B7-4034-AA23-20B0A30CAF11}
EnOcean EEP D20101 = {5F30BDCD-487F-44EE-9795-82C5DD429F2D}
EnOcean EEP D20102 = {C3825266-A6DE-44B6-97B4-C0BCFB6BD52B}
EnOcean EEP D20103 = {EAF7026C-A0DB-4B25-8DFD-D4FAB7A3EFCF}
EnOcean EEP D20104 = {5B38D44B-A570-4381-B719-8BFB58387AA1}
EnOcean EEP D20105 = {19FDCECC-0735-4ADA-8304-3AF53C919668}
EnOcean EEP D20106 = {1881B19B-A03C-437D-934D-28C598F13C39}
EnOcean EEP D20107 = {06DFB7CC-9945-4E1D-B08D-C505F4A7D2B4}
EnOcean EEP D20108 = {C885AB2C-7D83-4274-9420-EFEA5B8B0908}
EnOcean EEP D20109 = {BFDADCB0-BAB5-45BC-BF7A-1D19EA0FF31D}
EnOcean EEP D2010A = {6A37AC89-EFF0-40D8-88A1-8B24478FEE76}
EnOcean EEP D2010B = {F054B2EB-D812-47ED-B73C-22FBC0ADA667}
EnOcean EEP D2010C = {0389DA40-1B2A-446C-9448-03DED7977DC0}
EnOcean EEP D2010D = {744C3ACE-4680-4E1D-966F-CC959B25DFD6}
EnOcean EEP D2010E = {7E11E659-98E1-45A1-A9DB-29D337423C92}
EnOcean EEP D2010F = {AE62BF01-6C90-4FC2-8E1E-75EB5516BCF0}
EnOcean EEP D20110 = {699264EC-BEF1-4426-B501-687EA30C03B1}
EnOcean EEP D20111 = {21DDC756-E3CD-4B2D-B2F4-86092918A832}
EnOcean EEP D20112 = {47804DFF-5534-4256-8938-2C5D018736A3}
EnOcean EEP D20113 = {783B1089-4A50-4973-A522-C5288B9E1909}
EnOcean EEP D20114 = {A08C2716-CF6A-472C-A303-5C37C57A65BB}
EnOcean EEP D20300 = {8DA41914-45A6-8F0C-C935-178F76A36C42}
EnOcean EEP D2030A = {B24CF984-5CD7-B0D7-9661-41E6F2CEA0E7}
EnOcean EEP D20310 = {C14DBE59-E9B6-C9B7-7DEF-D98B8ADBA6F3}
EnOcean EEP D20601 = {6E5F79FE-3F0B-4CCE-8786-E8DD8893185B}
EnOcean EEP D20700 = {832ABD55-1173-B194-EB3F-D23681113A01}
EnOcean EEP D21101 = {3B1E2E8A-7C09-F58C-2841-3EF2D7C67F7A}
EnOcean EEP D21102 = {ED6AB19B-5A4A-80FD-BC4B-C07EE7F9915A}
EnOcean EEP D21103 = {7973060A-0241-E1E5-6E4B-CACBB08ACA76}
EnOcean EEP D21104 = {CC1482D1-6AD9-2199-C5E5-AD4EB6926455}
EnOcean EEP D21105 = {360F32BD-D9D5-5233-966A-63EAF54F671C}
EnOcean EEP D21106 = {8B2F1F85-A51C-0606-7CF3-8F980FEADB12}
EnOcean EEP D21107 = {F84B8E1B-B0DF-9383-1F6E-56EFAFB405A8}
EnOcean EEP D21108 = {1828E2A3-D83B-1433-46BF-AD0F11FF07DC}
EnOcean EEP D21430 = {1858BB3E-78BD-B090-7798-F1C0C26D912E}
EnOcean EEP D21500 = {75CA6030-43B9-8CF6-5901-E2DEF86E5249}
EnOcean EEP D23200 = {F60551AF-5D2B-4560-8BDD-7D1474C7A490}
EnOcean EEP D23201 = {C3B79AA9-54DB-4AE4-8ED4-3F954C723465}
EnOcean EEP D23202 = {0A03908E-694E-4CB1-BD35-AF7777504BFE}
EnOcean EEP D2A001 = {EA335B84-7E0A-F982-32CE-B50B60FC8E39}
EnOcean EEP D50001RX = {432FF87E-4497-48D6-8ED9-EE7104D50001}
EnOcean EEP F60101RX = {B9ED3CC4-A354-0420-A7D3-9AFC6C721FB3}
EnOcean EEP F60201RX = {432FF87E-4497-48D6-8ED9-EE7104F60201}
EnOcean EEP F60202RX = {432FF87E-4497-48D6-8ED9-EE7104F60202}
EnOcean EEP F60203RX = {432FF87E-4497-48D6-8ED9-EE7104F60203}
EnOcean EEP F60204RX = {432FF87E-4497-48D6-8ED9-EE7104F60204}
EnOcean EEP F60301RX = {432FF87E-4497-48D6-8ED9-EE7104F60301}
EnOcean EEP F60302RX = {432FF87E-4497-48D6-8ED9-EE7104F60302}
EnOcean EEP F60401RX = {432FF87E-4497-48D6-8ED9-EE7104F60401}
EnOcean EEP F60402RX = {432FF87E-4497-48D6-8ED9-EE7104F60402}
EnOcean EEP F60500RX = {74DB7CEE-18F9-478D-9FBC-CA857F807C50}
EnOcean EEP F60501RX = {432FF87E-4497-48D6-8ED9-EE7104F60501}
EnOcean EEP F60502RX = {8D42EFEE-119C-4CA8-BED2-66D18921749E}
EnOcean EEP F61000RX = {432FF87E-4497-48D6-8ED9-EE7104F61000}
EnOcean EEP F61001RX = {C31A7F85-4E76-E9C9-F920-2953DE737560}
EnOcean EltakoDimmer = {48909406-A2B9-4990-934F-28B9A80CD079}
EnOcean EltakoFABH130 = {03AEBCA9-1140-969E-7C72-728A1F30CD55}
EnOcean EltakoFABH65S = {0E8E3267-5CFA-4A52-AB3E-899170D16116}
EnOcean EltakoFAFT60 = {0BE195DC-6002-4D99-A566-3B9B0B57FAD6}
EnOcean EltakoFAH60 = {AF827EB8-08A3-434D-9690-424AFF06C698}
EnOcean EltakoFHK14 = {7C25F5A6-ED34-4FB4-8A6D-D49DFE636CDC}
EnOcean EltakoFKC = {40C99CC9-EC04-49C8-BB9B-73E21B6FDDDD}
EnOcean EltakoFRW = {40C99CC9-EC04-49C8-BB9B-73E21B6FEEEE}
EnOcean EltakoFSS12 = {7124C1BC-B260-4C5E-BF00-B38D3C7B5CB7}
EnOcean EltakoFTR65 = {40C99CC9-EC04-49C8-BB9B-73E21B6FFF65}
EnOcean EltakoFWS61 = {9E4572C0-C306-4F00-B536-E75B4950F094}
EnOcean EltakoFZS = {40C99CC9-EC04-49C8-BB9B-73E21B6FCCCC}
EnOcean EltakoRGBW = {71072C70-7ADF-6CC5-8D6F-7368132584F8}
EnOcean EltakoShutter = {1463CAE7-C7D5-4623-8539-DD7ADA6E92A9}
EnOcean EltakoSwitch = {FD46DA33-724B-489E-A931-C00BFD0166C9}
EnOcean Gateway = {A52FEFE9-7858-4B8E-A96E-26E15CB944F7}
EnOcean Hoppe = {1C8D7E80-3ED1-4117-BB53-9C5F61B1BEF3}
EnOcean Opus = {9B1F32CD-CD74-409A-9820-E5FFF064449A}
EnOcean PTM200 = {40C99CC9-EC04-49C8-BB9B-73E21B6FA265}
EnOcean PTM200RX = {63484585-F8AD-4780-BAFD-3C0353641046}
EnOcean RCM100 = {8492CEAF-ED62-4634-8A2F-B09A7CEDDE5B}
EnOcean STM100 = {FA1479DE-C0C1-433D-98BC-EA7C298D1AA5}
EnOcean STM250 = {B01DE819-EA69-4FC1-91AB-4D9FF8D55370}
EnOcean Shutter = {1463CAE7-C7D5-4623-8539-DD7ADA6E92AA}
EnOcean SmartDrive MX = {004A19B5-6E60-41A3-813C-7653ABAB6116}
EnOcean Thermokon SR0x = {B4249BC6-5BA8-45E3-B506-86680935D4EE}
EnOcean Thermokon Thanos = {54E114A3-F9B6-4747-A07E-D2A064629627}
EnOcean Valve Actuator = {004A19B5-6E60-41A3-813C-A11DC00B6116}
EnOcean alphaEOS SENSE TF-H = {F98CD462-0147-4A79-A0DF-448580E01629}
Event Control = {ED573B53-8991-4866-B28C-CBE44C59A2DA}
FHT = {A89F8DFA-A439-4BF1-B7CB-43D047208DDD}
FHZ = {57040540-4432-4220-8D2D-4676B57E223D}
FS10 = {6D508C91-F197-44A9-A1AB-A27F97A18A5F}
FS10 Gateway = {753E7267-7558-49D3-ACFB-86755C28318D}
FS20 = {48FCFDC1-11A5-4309-BB0B-A0DB8042A969}
FS20EX = {56800073-A809-4513-9618-1C593EE1240C}
HID = {E6D7692A-7F4C-441D-827B-64062CFE1C02}
HMS = {2FD7576A-D2AD-47EE-9779-A502F23CABB3}
HTTP Client = {4CB91589-CE01-4700-906F-26320EFCF6C4}
Heating Control = {FF7AF0F4-D616-4EF5-B73A-D49C56CF4C92}
Heating Control Legacy = {3F52FA69-77F5-4DE6-8B2A-347452AC5F8F}
HomeMatic Configurator = {5214C3C6-91BC-4FE1-A2D9-A3920261DA74}
HomeMatic Device = {EE4A81C6-5C90-4DB7-AD2F-F6BBD521412E}
HomeMatic Discovery = {3718244C-71A2-B20D-F754-DF5C79340AB4}
HomeMatic Socket = {A151ECE9-D733-4FB9-AA15-7F7DD10C58AF}
IMAP = {CABFCCA1-FBFF-4AB7-B11B-9879E67E152F}
IPS-868 AD = {134A1CFF-3CAA-4D2E-8517-F9BFDE7555C9}
IPS-868 Accelerometer = {304B6E9A-A518-43C6-80E8-D066879E7FD1}
IPS-868 AirQuality = {2B2842ED-0BB9-45FE-934C-1DFE07E1A724}
IPS-868 Configurator = {0A3CCE10-7613-1C54-0721-57023C98EFDA}
IPS-868 Counter = {134A1CFF-3CAA-4D2E-8517-F9BFDE7544C9}
IPS-868 DA = {134A1CFF-3CAA-4D2E-8517-F9BFDE7566C9}
IPS-868 Data = {984FFE86-71BE-48D3-943E-45277BECB52D}
IPS-868 Discovery = {F2B8A368-F9F2-7919-B299-79DC5B64B8A4}
IPS-868 Display = {9542B617-C603-4E8A-BFDE-DD69663F0226}
IPS-868 Display Input = {FBF6F86C-4901-4957-8D08-2B2CBC1DF71A}
IPS-868 Display Output = {C8CF38E9-BEAA-4149-A9ED-C8AAE04E8A6D}
IPS-868 Gateway = {995946C3-7995-48A5-86E1-6FB16C3A0F8A}
IPS-868 Input = {5509B26C-F2F7-428F-973B-FD5D07C80111}
IPS-868 Level = {C7A069AB-E2BE-4AD2-BB51-A7B52D6FAC4E}
IPS-868 Servo = {D2C92D2D-FC07-4545-AEBA-4294FD9D3035}
IPS-868 Servo Input = {7D07671F-65FF-4D9A-B521-9F0964DD9399}
IPS-868 Stripe = {7AF52E55-4994-44AE-9DB8-752895F1EB76}
IPS-868 Stripe Input = {26B22717-924E-4D58-B091-C98E49812238}
IPS-868 Thermo = {95D715AA-AB5A-4423-AD7B-5081EB542971}
IPS-868 Tracker = {50460BD9-FA93-4DE0-976A-55208C90DF15}
IPS-868 WatchDogTimer = {9F88A462-BFDA-47C5-990C-B9E20D2F861E}
IRTrans Device = {899DBC68-0147-4528-B95D-D43C568D4E56}
IRTrans Gateway = {0F0F74EF-2304-4C23-840F-EC1C5B9A9A82}
Image Grabber = {5A5D5DBD-53AB-4826-8B09-71E9E4E981E5}
JSON Decoder = {9F976F04-7DC4-BB2D-38CA-67C1AFC84C7A}
KNX Configurator = {33765ABB-CFA5-40AA-89C0-A7CEA89CFE7A}
KNX DPT 1 = {F3058AB2-AFDC-4479-A053-5F4599DF6F5B}
KNX DPT 10 = {2D26EF69-C3BC-4738-879D-FB493DD166BF}
KNX DPT 11 = {4A5AE804-59E2-41EA-ABCE-3BC80F33543C}
KNX DPT 12 = {AD992707-B7DC-4255-96DE-B70057CEC989}
KNX DPT 13 = {BAEA5454-4256-48AA-982B-538201A374D4}
KNX DPT 14 = {E8C3C9ED-A6FA-45FF-A942-A206FEEE360C}
KNX DPT 15 = {16B72DE7-3C8B-4709-8819-6A260E890A12}
KNX DPT 16 = {2146FF76-FAE6-46B6-9630-73E5F3FAE190}
KNX DPT 17 = {E8A0352C-B13F-4691-AAF5-586DE502569E}
KNX DPT 18 = {8B2A23B9-6B96-4F76-9EC8-5365BA7E9441}
KNX DPT 19 = {8456D139-6771-4821-8A37-9304BEAA1BFD}
KNX DPT 2 = {434A6354-235F-4484-8883-9FF30616E3FB}
KNX DPT 20 = {C9304609-D1CD-4F07-BE7C-E5546A91A5DF}
KNX DPT 200 = {04ED3286-C982-436F-A01E-8A03C2E976A8}
KNX DPT 201 = {5F14B9D5-297D-4C25-9E45-92BF7B7C3F02}
KNX DPT 202 = {22726542-A2B6-4FBB-BB98-BA5927932C23}
KNX DPT 203 = {3243B56D-DE90-4BED-8E07-E4DEE777C6AF}
KNX DPT 204 = {06E5F74A-BC1F-4F69-BBE6-8AD663058CD9}
KNX DPT 205 = {28837D84-085F-4701-ADA0-CF9A8F49F591}
KNX DPT 206 = {F5E3C9F5-A0E8-4919-BB38-0551AE5886A7}
KNX DPT 207 = {EE68B239-8E3A-4F54-9501-96CB4B2700A4}
KNX DPT 209 = {D9A125D0-8D82-4808-A024-0FC5E82799D6}
KNX DPT 21 = {8941E278-1901-478D-AFC8-807E3515DD28}
KNX DPT 210 = {68E7C9CE-724E-4CBE-8206-A61AD9A6A328}
KNX DPT 211 = {0636647E-EB02-4EE3-857E-0B69C0E8AA3D}
KNX DPT 212 = {4D8AD2DA-5669-4BEB-B9C7-983DA48A7777}
KNX DPT 213 = {DEA88D19-78B6-4D51-89FF-E3958151863D}
KNX DPT 214 = {AC33D286-FBBC-40BE-91CC-C470FB896C04}
KNX DPT 215 = {619D8815-1E90-4A7A-B51D-14DCB2FCE0E0}
KNX DPT 216 = {F5339A58-E891-4A22-AF29-3C801D3092EE}
KNX DPT 217 = {9CF216A5-370F-4BD9-92F0-B7BF87933A76}
KNX DPT 218 = {DB54CF66-4ED5-4457-A1EF-A3DF52EC135F}
KNX DPT 219 = {7EA00021-4300-4B9F-A274-863E1DD41695}
KNX DPT 22 = {DD0F4EF5-3C71-44F1-A346-397D34809D30}
KNX DPT 220 = {14BBE7DF-8442-4ED8-9D7D-C00B3E1B892A}
KNX DPT 221 = {3C16BD4B-45BF-435A-84DA-D7908F2D6140}
KNX DPT 222 = {3AD960E1-E129-4D96-BFAC-696AC149C629}
KNX DPT 223 = {EA6A0F52-ECEF-46D2-A942-96DDED471732}
KNX DPT 224 = {7245A626-1864-4834-A181-EE4FB4AD50DC}
KNX DPT 225 = {CC6C64D0-2F48-4497-A6A6-2120BAE5CD52}
KNX DPT 229 = {3F20B758-71DD-4C0B-A169-D4B59B023555}
KNX DPT 23 = {7CA94B7E-6460-4D68-8568-EE4B0912C5BF}
KNX DPT 230 = {88546CFE-1265-494C-B80C-1A3A6E1E671D}
KNX DPT 231 = {44A18680-880B-4ACC-9E84-8FB79FB9D727}
KNX DPT 232 = {DE2E3FBF-1588-4293-B76C-C90446D9E5F1}
KNX DPT 234 = {C667FC98-9FE4-4953-87ED-2B75F59704A4}
KNX DPT 235 = {960A48AD-36AB-4174-A298-F31E99014738}
KNX DPT 236 = {8A57A40D-AE55-42D5-BF33-4F1E0DDA1F8C}
KNX DPT 237 = {E3E1F95B-3356-4F6A-A419-9486125E023A}
KNX DPT 238 = {117D49A5-7D8F-4509-8669-F44972F072DD}
KNX DPT 239 = {F8AE906F-76E2-4464-96DA-B9A6D19049C9}
KNX DPT 240 = {CC5F383D-975B-44E9-BC18-C64FA2698CC0}
KNX DPT 241 = {A26BC82A-5953-4385-9FAA-5A5D3814D2B5}
KNX DPT 242 = {F565EF9F-30A5-4E1C-BA10-7BC15AB4EFB4}
KNX DPT 249 = {34B83F38-03F2-4D15-9031-70197CE9456E}
KNX DPT 25 = {9FB4BD67-5E67-4E94-B8C8-71D609048BBB}
KNX DPT 251 = {9165E3E2-8ED2-4152-BEFF-97793823FE4D}
KNX DPT 26 = {135F8FCF-DAFC-46AA-85EC-94C911FD21DF}
KNX DPT 27 = {EDE5D3E1-FB5A-48EE-A944-0A4ED0FBACC1}
KNX DPT 28 = {3E175751-4B84-4E8E-98C1-BF0D12835F2C}
KNX DPT 29 = {AA9ED268-3B37-4962-85BB-CBC73CB11618}
KNX DPT 3 = {EB931B1A-3A4A-47E9-AC67-D2A0D285B60C}
KNX DPT 30 = {2E7AADF5-F1DF-476D-B207-22D204C4AD28}
KNX DPT 31 = {5AD8B9C3-5A87-4426-B9A1-C7935022A680}
KNX DPT 4 = {6891595A-BF7C-4F4C-8A3B-7EA7346C8657}
KNX DPT 5 = {EBD0EE8D-DFA5-449F-BBE4-49CFC5F0EEB4}
KNX DPT 6 = {BAC22632-D6ED-4D88-82EA-726D700C4F2A}
KNX DPT 7 = {DCAFED37-B20B-4EEB-AA44-799C9B804557}
KNX DPT 8 = {7852DBDE-C68A-4A3E-88AF-155B99605371}
KNX DPT 9 = {95CDE37D-72CE-4360-BB91-573757C274A0}
KNX Discovery = {3519D734-79C9-4E7A-9E9B-91B6374D1C10}
KNX EIS Group = {D62B95D3-0C5E-406E-B1D9-8D102E50F64B}
KNX Gateway = {1C902193-B044-43B8-9433-419F09C641B8}
KNX RGB = {4D7F7548-0979-4ABD-9BB3-81F9477C0903}
KNX RGBW = {81F54858-72B1-4C2C-8CE3-7E00A3168378}
KNX Shutter = {24A9D68D-7B98-4D74-9BAE-3645D435A9EF}
KS300 = {9D21F700-6F67-4FBB-ACC2-AA42420A0486}
LCN Configurator = {0F64973F-4669-4272-BDB3-6338D0350269}
LCN Data = {A26E7E5A-A7C5-4063-8BE0-ED8BB26F8411}
LCN Display = {A26E7E5A-A7C5-4063-8BE0-ED8BB26F8522}
LCN Gateway = {9BDFC391-DEFF-4B71-A76B-604DBA80F207}
LCN Module = {0E31FED6-E465-4621-95D4-AAF2683C41EC}
LCN RGBW = {839D1208-D4BB-4FA7-86FA-AA9FBF96ED17}
LCN Shutter = {C81E019F-6341-4748-8644-1C29D99B813E}
LCN ShutterMotor = {C81E019F-6341-4748-8644-1C29D99B813F}
LCN Unit = {2D871359-14D8-493F-9B01-26432E3A710F}
LCN Value = {0102BDC9-3B85-4A11-968D-7D314DA07C06}
LevelJet = {D64B904C-5312-443C-A2F3-03201ED9811C}
Location Control = {45E97A63-F870-408A-B259-2933F7EABF74}
M-Bus Configurator = {73336CB8-B5E5-187E-8BB8-CC4F32BF127D}
M-Bus Device = {B53BE2E5-892D-4537-94AC-EAC68A469188}
M-Bus Discovery = {6BED8C28-002F-66B7-07B5-4145D4408F34}
M-Bus Gateway = {301AB802-23CD-4DE2-91D1-6E3BC9BF03FC}
MQTT Client = {F7A0DD2E-7684-95C0-64C2-D2A9DC47577B}
MQTT Client Configurator = {2408C0E0-E672-7FE5-414B-F78C9B9244E4}
MQTT Client Device = {91D174F2-AE0F-B8D8-5EF4-6232B9083CCF}
MQTT Server = {C6D2AEB3-6E1F-4B2E-8E69-3A1A00246850}
MQTT Server Configurator = {CC4F15B1-81C2-4F45-8D53-972F0C9C8103}
MQTT Server Device = {01C00ADD-D04E-452E-B66A-D253278743FE}
Media Player = {2999EBBB-5D36-407E-A52B-E9142A45F19C}
ModBus Address = {CB197E50-273D-4535-8C91-BB35273E3CA5}
ModBus Configurator = {8C1E6AC6-4C45-067A-3696-6B4284B75C4B}
ModBus Gateway = {A5F663AB-C400-4FE5-B207-4D67CC030564}
Module Control = {B8A5067A-AFC2-3798-FEDC-BCD02A45615E}
Multicast Socket = {BAB408E0-0A0F-48C3-B14E-9FB2FA81F66A}
Notification Control = {D4B231D6-8141-4B9E-9B32-82DA3AEEAB78}
OZW Configurator = {62BDA2F6-6206-4DC3-9431-4328B5890836}
OZW DataPoint = {422A36CD-5565-4CDC-9FC4-242D3C810901}
OZW Device = {CE54AFB0-625A-4F37-B5C1-EAF1FD2A1DA6}
OZW Gateway = {1D60A51E-FF04-4D82-9E0D-04B3A11EF13F}
OneWire Configurator = {F462BFF3-6772-4720-8450-49E6E2820643}
OneWire Discovery = {1739B440-4A46-F5FF-8640-F9DF3D14C06B}
OneWire F05 = {F1B54BB1-DC7D-42D9-A973-6CA4789E358F}
OneWire F10 = {685D4911-57CC-43AF-BA36-183EF2C8518F}
OneWire F12 = {50DB3978-CF6A-4BCE-87DF-5BB45D900628}
OneWire F1D = {88A63FF8-832B-48E3-B989-A416C7908E6A}
OneWire F20 = {5DF182B0-01DF-4D8A-82CD-E646FD9BF0B2}
OneWire F26 = {301FA314-65F8-4317-8BF5-729CF8664F54}
OneWire F28 = {766E337F-A707-48CC-A323-70D7E77E3F8C}
OneWire F29 = {6A75828A-25CD-4CF3-83EA-DAAB914030A7}
OneWire F2C = {E02955B3-49E4-47A9-A9ED-2C71401F6D6E}
OneWire F3A = {BD0F2622-F67C-4248-9A04-316DF13914C3}
OneWire Gateway = {CED1D815-2477-4B05-8F65-0E4475913063}
POP3 = {69CA7DBF-5FCE-4FDF-9F36-C05E0136ECFD}
Popup Module = {5EA439B8-FB5C-4B81-AA35-1D14F4EA9821}
Presence Control = {B263AFBC-950F-462C-95B1-E3ACACE0B9B0}
Register Variable = {F3855B3C-7CD6-47CA-97AB-E66D346C037F}
SMS = {96102E00-FD8C-4DD3-A3C2-376A44895AB1}
SMS REST = {96102E00-FD8C-4DD3-A3C2-376A44895AC2}
SMTP = {375EAF21-35EF-4BC4-83B3-C780FD8BD88A}
SSDP Control = {FFFFA648-B296-E785-96ED-065F7CEE6F29}
SSE Client = {2FADB4B7-FDAB-3C64-3E2C-068A4809849A}
Serial Port = {6DC3D946-0D31-450F-A8C6-C42DB8D7D4F1}
Server Socket = {8062CF2B-600E-41D6-AD4B-1BA66C32D6ED}
Shutter Control = {9512FC2C-7999-4BD0-B322-B6C49BD09127}
Shutter Control Legacy = {542CC907-CA63-4E7A-A8C7-92F74639FA4C}
Siemens Configurator = {691B4B06-C774-BA52-6C63-B88D5EDD79EB}
Siemens Device = {932076B1-B18E-4AB6-AB6D-275ED30B62DB}
Siemens Gateway = {1B0A36F7-343F-42F3-8181-0748819FB324}
Skin Control = {E8C1043A-E2C2-4CC8-88DC-CBF02D45E15E}
Store Control = {F45B5D1F-56AE-4C61-9AB2-C87C63149EC3}
TMEX = {ABEE57FB-E243-461D-B2F7-4D176ACB7C7C}
Text Parser = {4B00C7F7-1A6D-4795-A2D2-08151854D259}
Text To Speech = {684CC410-6777-46DD-A33F-C18AC615BB94}
ThermoJet = {C3380B6E-2351-4A19-9668-A17960F97E51}
UDP Socket = {82347F20-F541-41E1-AC5B-A636FD3AE2D8}
UVR1611 = {0A8F9D69-E78B-4EAB-8E26-C8A4ACF7FA25}
Universal RX = {23D1E4CD-77E9-4F4B-B8B3-53AE81222AF6}
Util Control = {B69010EA-96D5-46DF-B885-24821B8C8DBD}
Velleman USB = {8CE70CD0-6674-4907-B3CE-F6E5235C9938}
Virtual IO = {6179ED6A-FC31-413C-BB8E-1204150CF376}
VoIP = {A4224A63-49EA-445F-8422-22EF99D8F624}
WMRS200 = {DD2A4676-82C6-4154-9AAD-DE30668D53B0}
WMRS200 Gateway = {E4FDC411-95D5-453C-B731-0CEB0483E663}
WS Client = {D68FD31F-0E90-7019-F16C-1949BD3079EF}
WebFront Visualization = {3565B1F2-8F7B-4311-A4B6-1BF1D868F39E}
WebHook Control = {015A6EB8-D6E5-4B93-B496-0D3F77AE9FE1}
WebOAuth Control = {F99BF07D-CECA-438B-A497-E4B55F139D37}
WebServer = {D83E9CCF-9869-420F-8306-2B043E9BA180}
WinLIRC = {19E51FC2-064B-4A51-8995-11FEFF7F129A}
WuT Counter = {5F1C5261-07A2-4A7E-9AC4-88AF9ED29420}
WuT Gateway = {01CA6888-C833-484E-A3F3-806535421CB7}
WuT Input = {C3D0F82C-CD07-4AA8-AE5C-7AD983FE91F3}
WuT Output = {E85C40B3-C1E9-4A60-85C7-6CDDA3D8D7BF}
WuT ThermoHygro = {2EF634A4-D96D-4018-BD90-94E487A89D49}
XBee Gateway = {7FA47C08-E31B-44A6-9E50-20C4DDD3E081}
XBee Splitter = {9D5DCE79-1A97-4531-9D10-68839F4BEAAC}
Z-Wave Configurator = {2D7CA355-2C51-4430-8F67-4E397EAAEA19}
Z-Wave Discovery = {5754F842-9D3E-BF8D-E3FC-8B1237AEC7E5}
Z-Wave Gateway = {4EF72D56-BF9F-4347-8F0A-2035D241116F}
Z-Wave Module = {101352E1-88C7-4F16-998B-E20D50779AF6}
dS Apartment = {555C65F5-F436-467F-A2B1-DAA1BB02CA3B}
dS Configurator = {7CADC358-60B0-4D91-9825-27E9029B62C4}
dS Expert = {1822D865-2093-32A1-6999-280C82E669EB}
dS Joker = {DB54D0EC-64C4-4941-9B64-2337183C9C2E}
dS Light = {DB54D0DB-64C3-4930-9B53-2337183C9C1D}
dS Shutter = {3DDA1E2B-B807-4680-AB6D-E7E8FBD6093A}
dS Splitter = {8D7872F4-CAC3-409D-926B-CCF1BA9E937B}
dS Zone = {4E0FE8A0-1A1E-460A-9446-2D18B3635310}
ekey Fingerprint = {9AB0DD38-A396-4D35-81A1-2FB6A3992332}
xComfort Binary Input = {3040A77D-3E9C-42D4-A1B6-329EFE8086DB}
xComfort Configurator = {5DD921D4-4712-443F-B89F-03434A4DBF94}
xComfort Dimmer = {8050FEEC-C875-4BDD-9143-D15134B89D35}
xComfort Energy = {814067F0-EACB-43C3-99BD-5CB9B2F8FB9E}
xComfort Gateway = {D2DCE381-19A7-4D14-B819-49C0539BC350}
xComfort HRV = {E4693C3F-95F1-48B6-9443-4A6B3EE0FACA}
xComfort Heating = {586D59EE-04A8-4896-B49D-63B4DD9618EF}
xComfort Humidity = {3EBA1AB7-72CA-48D2-8F89-813E085D41BB}
xComfort Impulse = {A374DCF0-CEDE-4EB7-B6A8-E92787E19B25}
xComfort One Channel Heating = {62444FDF-FBF0-8F98-50B3-B1E85ADD86E2}
xComfort Remote = {DCBD8143-83AB-4068-8FC0-0C92A93AA8A8}
xComfort Room Control = {1A1C4C67-C99D-4D3E-8A34-23581CE8CCAA}
xComfort Shutter = {1B7B5B7D-CAA9-4AB5-B9D8-EC805EC955AD}
xComfort Switch = {27DD9788-802E-45B7-BA54-FB97141398F7}
xComfort Temperature = {591B4A05-E5BF-4EEA-BC34-36E6F1CC9D56}
xComfort Value RX = {DA2FCC12-2DE1-404A-8A5E-1C6AF05F96A2}
xComfort Value TX = {ED6A1E00-81C7-416F-9F97-1F2CC8F45B15}
