IPS_SetEventTriggerValue
boolean IPS_SetEventTriggerValue (int $EventID, variant $TriggerValue)
| EventID | ID of the event to be changed |
| TriggerValue | Value/ type, depending on TriggerVariableID |
Indicates the value/threshold at which the event should be run.
The TriggerType of the event must be set to:
- On limit drop
- On limit exceed
- On value
The limit must be specified as the correct type. Otherwise the comparison may fail or be triggered unexpectedly.
IPS_SetEventTriggerValue($EventID, true); //Trigger only for TRUE values
