IPS_SetEventScript
 boolean IPS_SetEventScript (int $EventID, string $EventScript)
EventID
ID of the event to be changed
EventScript
PHP code without PHP tags (<? ... ?>)
The executed Action of the Event is set to "Execute PHP Code" and the code to EventScript. The PHP code will be given directly without the PHP tags (<? ...?>).
The list of the System Variables shows what specific variables are available.
//Assign the script content to the event
IPS_SetEventScript($EventID, "echo linked object: ".$_IPS['TARGET']);
