IPS_SetEventConditionTimeRule
Require: Symcon >= 4.4
bool IPS_SetEventConditionTimeRule (int $EventID, int $ConditionID, int $RuleID, int $Comparison, int $Hour, int $Minute, int $Second)
| EventID | ID of the event to be changed |
| ConditionID | ID of the condition that contains the rule |
| RuleID | Unique ID for this rule. IDs need to be unique for this condition only. |
| Comparison |
| Hour | Hour value (0..23) with which the current time is compared |
| Minute | Minute value (0..59) with which the current time is compared |
| Second | Second value (0..59) with which the current time is compared |
This function modifies the rule with the ID RuleID of the condition with the ID ConditionID of the event with the ID EventID. The rule compares the current time with Hour, Minute and Second, according to the comparison operation Comparison. If there is no rule with the ID RuleID, one will be created.
If one of the values is outside of the valid range (Hour < 0 or > 23, Minute < 0 or > 59, Second < 0 or > 59), the rule with the ID RuleID will be deleted. If no rule with this ID exists, an error is raised.
Which rule ID contains which rule can be looked up via IPS_GetEvent.
// Create a root condition
IPS_SetEventCondition(12345, 0, 0, EVENT_CONDITION_OPERATION_AND);
// Adds/modifies the rule with the ID 2 for the event with the object ID 12345
// It has to be exactly 10:30 p.m. for this rule to be met.
IPS_SetEventConditionTimeRule(12345, 0, 2, EVENTCONDITIONCOMPARISON_EQUAL, 22, 30, 0);
// Delete the rule with ID 1
IPS_SetEventConditionTimeRule(12345, 0, 1, 0, -1, 0, 0);
