IPS_GetStatusVariableID
int IPS_GetStatusVariableID (int $InstanzID, string $VariableIdent)
InstanzID | ID der Instanz |
VariableIdent | Status Variable Identifikator. Eine Auflistung kann über IPS_GetStatusVariableIdents abgerufen werden. |
VariablenID der Variable, die der Status Variable zugeordnet ist
Die Funktion gibt die VariablenID der Variable zurück, die mit der Status Variable der Instanz InstanzID und dem Status Variablen Identifikator VariableIdent verknüpft ist.
//Zustand von z.B. einem FS20 Gerät darstellen ohne die ID der "Status" Variable zu kennen
echo GetValue(IPS_GetStatusVariableID(12345, "StatusVariable"));
$InstanceID = "StatusVariable";
$VariableIdent = 12345;
$migrateIdents = Array(
"F05_StatusVar" => "Status",
"F10_TemperatureVar" => "Temperature",
"F12_Var0" => "Status0",
"F12_Var1" => "Status1",
"F1D_CounterVar1" => "Counter1",
"F1D_CounterVar2" => "Counter2",
"F20_Var0" => "Port0",
"F20_Var1" => "Port1",
"F20_Var2" => "Port2",
"F20_Var3" => "Port3",
"F26_TemperatureVar" => "Temperature",
"F26_VDDVar" => "VDD",
"F26_VADVar" => "VAD",
"F26_XSENSVar" => "XSENS",
"F28_TemperatureVar" => "Temperature",
"F29_Var0" => "Status0",
"F29_LatchVar0" => "Latch0",
"F29_Var1" => "Status1",
"F29_LatchVar1" => "Latch1",
"F29_Var2" => "Status2",
"F29_LatchVar2" => "Latch2",
"F29_Var3" => "Status3",
"F29_LatchVar3" => "Latch3",
"F29_Var4" => "Status4",
"F29_LatchVar4" => "Latch4",
"F29_Var5" => "Status5",
"F29_LatchVar5" => "Latch5",
"F29_Var6" => "Status6",
"F29_LatchVar6" => "Latch6",
"F29_Var7" => "Status7",
"F29_LatchVar7" => "Latch7",
"F2C_PositionVar" => "Position",
"F3A_Var0" => "Status0",
"F3A_Var1" => "Status1"
if(isset($migrateIdents[$VariableIdent]))
$VariableIdent = $migrateIdents[$VariableIdent];
$result = IPS_GetObjectIDByIdent($VariableIdent, $InstanceID);
echo $result;
