Keyboard Shortcuts
General Keyboard Shortcuts
Shortcut | Description |
Esc | Close the current tab |
Keyboard Shortcuts in Script Editor
F3 | Search next |
Shift + F3 | Search previous |
Ctrl + A | Select all |
Ctrl + C | Copy text via Ctrl + V |
Ctrl + E | Execute |
Ctrl + F | Search |
Ctrl + H | Replace |
Ctrl + O | Select object |
Ctrl + R | Rename script |
Ctrl + S | Save |
Ctrl + D | Display events |
Ctrl + X | Move text via Ctrl + V |
Ctrl + Shift + K | Delete row |
Ctrl + V | Insert text from clipboard |
Ctrl + Z | Undo |
Ctrl + Shift + Z, Ctrl + Y | Redo |
Ctrl + Space | Display function list |
Ctrl + Shift + F | Search in all scripts |
Ctrl + Shift + H | Replace in all scripts |
Tastenkombinationen im Objektbaum
Enter | Open object or edit object if it cannot be opened |
Del | Delete object |
Alt + 0 | Add category |
Alt + 1 | Add instance |
Alt + 2 | Add variable |
Alt + 3 | Add script |
Alt + 4 | Add event |
Alt + 5 | Add media |
Alt + 6 | Add link |
Ctrl + C | Copy object via Ctrl + V, copy ObjectID to clipboard |
Ctrl + L | Create link to object via Ctrl + V |
Ctrl + X | Move object via Ctrl + V |
Ctrl + V | Copy, insert, or move object |
Ctrl + E | Execute object |
Ctrl + F | Search ID |
Ctrl + R, F2 | Rename object |
Ctrl + Enter | Edit object |
