Add object
In order to "Add a new object", the "+" in the lower right corner of the object tree must be clicked. The following dialog and selection of various objects appears:
Add object in the object tree
Alternatively, "right mouse button" can be used within the object tree to click on the desired position in the tree. The following context menu opens:
Add object using the context menu
