MXC_ShutterMoveUp
 boolean MXC_ShutterMoveUp (int $InstanceID)
Moves the shutter with the ID InstanceID upwards until MXC_ShutterStop is running or the end position is reached.
Note that the running time limitation on the MRF Moeller is programmed. IP Symcon can not influence this limitation.
MXC_ShutterMoveUp(12345); //Move upwards
