MXC_DimBrighter
 boolean MXC_DimBrighter (int $InstanceID)
Starts the dimming for the device with ID InstanceID at a higher intensity level. The process can be terminated with the command MXC_DimStop. If the maximum level is reached, the process will stop automatically. The status message is sent from the device, when the operation was terminated. There are no messages sent between.
MXC_DimBrigther(12345); //Dim brighter
IPS_Sleep(1000): //Wait 1 sec
MXC_DimStop(12345);
