WGW_UpdateWeatherData
Require: IP-Symcon >= 4.2
boolean WGW_UpdateWeatherData (int $InstanceID)
Updates the weather data (current/hourly/daily) of the Weatherground module with InstanceID InstanceID.
WGW_UpdateWeatherData(12345);
