WGW_UpdateStormWarningData
Require: IP-Symcon >= 4.2
boolean WGW_UpdateStormWarningData (int $InstanceID)
Updates the severe weather warnings of the Weatherground module with the InstanceID InstanceID.
WGW_UpdateStormWarningData(12345);
