Work Efficiency
Require: IP-Symcon >= 6.3
The efficiency is calculated.
function scope
- The efficiency for the past 365 days
- The efficiency for the past 30 days
software-installation
Using the Module Store, install the 'work efficiency' module.
Under 'Add Instance' the 'Work efficiency' module can be found using the quick filter.
configuration page
name | description |
Thermal energy (kWh) | Variable logged as counter |
Electrical Energy (kWh) | Variable which is logged as counter |
status variables
Name | Type | Description |
SPF Month | Float | Stands for the sessional performance facto on month |
SPF Year | Float | Stands for the sessional performance factor on year |
