Device list
Supported Gateways
The following wireless M-Bus gateways are compatible:
Manufacturer | Description |
SymBox with Wireless M-Bus extension Order now | Serial integrated module |
Wireless M-Bus LAN Gateway Order now |
IP Gateway |
Würth Elektronik 2605056083001 | METIS I, USB, AMB8465-M, integrated antenna |
Würth Elektronik 2607056283001 | METIS II, USB, AMB8665-M, external antenna |
IMST iU891A-XL | New model with external antenna |
IMST iM871-A | Old model |
Supported components
IP-Symcon supports the following encryption modes according to DIN EN 13757-7
- Mode 0 (no encryption)
- Mode 5 (OMS)
- Mode 7 (BSI)
IP-Symcon supports the following encryption modes according to DIN EN 13757-4
- AES-128-CTR
IP-Symcon supports the frame format A/B and the receive mode C/T. In addition, the somewhat more specialized Compact Frames, which are often used by Kamstrup devices, are supported.
