WC_PushMessageEx
Require: IP-Symcon >= 5.3
 boolean WC_PushMessageEx (int $InstanceID, string $HookPath, string $Text, string $DestinationAddress, int $DestinationPort)
ID des WebHook Control
HookPath
Path of the hook
Text
Message to send
DestinationAddress
IP address to send to
DestinationPort
Port to send to
Sends the message Message to a specific client on the hook HookPath of the WebHook Control with ID InstanceID. The client can be determined via the parameters of the IP address Target address and the target port Port.
// Sends "Hello World back" to the "test" hook of the WebHook Control with ID 12345. In addition, the client with the address $_SERVER["REMOTE_ADDR"] and port $_SERVER["REMOTE_PORT"] is determined as the recipient.
WC_PushMessageEx(12345, "/hook/test", "Hello world back", $_SERVER["REMOTE_ADDR"], $_SERVER["REMOTE_PORT"]);
