WFC_AudioNotification
Require: IP-Symcon >= 3.0
 boolean WFC_AudioNotification (int $InstanceID, string $Title, int $MediaID)
ID of the WebFront visualization
Title
Audio message title
MediaID
ID of the media object, which is of type "Sound”
Sends an audio message with Title to the WebFront assigned to the configurator with the ID InstanceID. The audio message appears as a small box in the upper right corner of the WebFront and is displayed for the playback duration.
Please note that not all browsers support all formats: http://www.w3schools.com/tags/tag_audio.asp
To be able to play "media files" in the WebFront, these must be made available as links in the "visible" area of the WebFront. These can also be stored invisibly. If this is not done, the WebFront cannot access the file and an error, that the instance cannot be found, is displayed.
Under iOS this function has no effect, as Apple disables the playback of sound files in the WebBrowser!
Under Android Browser and Android Chrome this function has no effect, as Google prevents the playback of sound files in the WebBrowser!
Under Android Chrome, the automatic playback of sound files can be activated. To do this, "Disable motion request for media playback" has to be enabled under about:flags and then the browser has to be restarted.
WFC_AudioNotification(12345, 'Gong!', 55541); //55541 is the ID of the media object in IP-Symcon
