WAA_CheckAlert
Require: IP-Symcon >= 4.2
 boolean WAA_CheckAlert (int $InstanzID, string $BorderValue, string $OldValue)
ID of the Instance
BorderValue
Border Value
OldValue
Old Value
Checks within the WaterAlarm with the InstanceID InstanceID whether a limit value was exceeded and sets the alarm variables
WAA_CheckAlert(12345, "LeakThreashold", "LeakBuffer");
