Thermostat (Simulation)
Simulates a thermostat.
range of functions
- Simulates a thermostat
Software installation
- Install the 'Virtual Devices' module via the Module Store.
Under 'Add instance', the 'Thermostat (simulation)' module can be found using the quick filter.
- Further information on adding instances can be found in the Instances documentation
Configuration page:
Name | Description |
Create logged values for the current temperature | |
hour value | table with the values to be logged |
status variables
Status variables
Name | Type | Description |
Set temperature | Float | Variable for setting the temperature |
Actual temperature | Float | Current temperature |
Visualization
The heating tile is displayed in the tile visualization.
