PV-System (Simulation)
Simulation of a PV system
range of functions
  • Simulation of a PV system
Software installation
  • Install the 'Virtual Devices' module via the Module Store.
Under 'Add instance', the 'PV system (simulation)' module can be found using the quick filter.
Configuration page:
Name Description
Power Specification of how much the PV system should consume
status variables and profiles
Status variables
Name Type Description
Generation Float Indicates how much the PV system generates
Profiles
Name Type
WattSlider.10 float
