Light (Simulation)
Simulates a light.
range of functions
  • Simulates a light
Software installation
Install the 'Virtual Devices' module via the Module Store.
Under 'Add instance', the 'Light (simulation)' module can be found using the quick filter.
status variables
Status variables
Name Type Description
Status Boolean Switches the light on/off.
Brightness Integer Switches the brightness of the light
Color Integer Switches the color of the light
Color temperature Integer Switches the color temperature of the light
Visualization
Initially displays the light tile with several options in the tile visualization.
