Heater (Simulation)
Simulates a heater.
range of functions
  • Simulates a heater.
Software installation
Install the 'Virtual Devices' module via the Module Store.
The 'Heater (simulation)' module can be found under 'Add instance' using the quick filter.
Configuration page:
Name Description
Power Specification of how much the heater should consume
Variance Specification of how much the consumption should fluctuate
Interval Time interval of the updates
status variables
Status variables
Name Type Description
Status Boolean Switches the heater on/off
Intensity Integer Switches the intensity of the heater
Consumption Float Displays the current consumption
