Counter (Simulation)
Simulates an adjustable number of counters.
range of functions
- Simulates several meters
Software installation
Install the 'Virtual Devices' module via the Module Store.
Under 'Add instance', the 'Counter (simulation)' module can be found using the quick filter.
- Further information on adding instances can be found in the Instances documentation
Configuration page:
Name | Description |
Number of counters | Number of counters to be simulated. |
Minimum value per hour | Minimum value to be added |
Maximum value per hour | Maximum value to be added |
Maximum distance between two subsequent values | Maximum distance between two values |
Use a different profile for each variable | Each counter receives a different profile |
Create graph | Creates a multigraph |
status variables
Status variables
Name | Type | Description |
Counter x | Float | A counter variable. x stands for the number of the counter |
Graph | Multigraph | A multigraph of the counters |
