VZ_WriteNewCounterValue
Require: IP-Symcon >= 6.0
void VZ_WriteNewCounterValue (int $InstanceID)
The function does not return any value.
Checks whether the value in variable "New counter reading" is negative, the "New counter reading" is less than the "Current counter reading" or the "New counter reading" exceeds the "Current counter reading" with the "Limit value". If these do not apply, the new value is set in "Current counter reading".
VZ_WriteNewCounterValue(12345);
