Virtual Counter
Require: IP-Symcon >= 6.0
The module provides an input mask for manually read meter readings. It accepts the manual entry, checks it for plausibility and transfers the value to a counter variable. To check for plausibility, a limit value can be set.
functional scope
- Check for plausibility
- Display of the last entered counter reading
- Input mask for new meter reading
Software installation
- Install the 'Virtual Counter' module via the Module Store.
Set_up_the_instances in IP-Symcon
- Under "Add Instance" the 'Virtual Counter' module can be found using the quick filter.
Configuration Page:
Name | Description |
Limit | Number by which a new counter value may increase at most. If the limit value is 0, it will not be checked |
Require confirmation to accept | If enabled, a script must be executed to trigger the plausibility check |
Activate Logging | Button, which activates the logging of the counter variable. It will be hidden if logging is enabled. |
status variables and profiles
Status variables
Name | Type | Description |
Current counter reading | Float | Displays the last entered counter reading |
New counter reading | String | Input variable for new counter reading |
Set safe new counter reading: Enter new counter reading | Boolean | Appears if the new counter reading exceeds the current one by the limit value. The value can still be accepted with confirmation |
Profile
Name | Type |
VZ.Confirm | Boolean |
VZ.NewCounterReading | String |
Scripts
Set Meter Reading | Executes the plausibility check and pushes the value into the vaiable "Current Meter Reading" if successful |
Webfront
Via the Visualization the new counter value can be entered and the script can be executed, furthermore the last accepted counter value is displayed.
