THL_Start
Require: IP-Symcon >= 5.0
 boolean THL_Start (int $InstanceID)
ID of the Instance
Activates the light in the staircase and starts the timer, which deactivates the light again. The timer is reset if it is called up again.
THL_Start(12345);
