SMTP_SendMailMediaEx
Require: IP-Symcon >= 4.0
boolean SMTP_SendMailMediaEx (int $InstanceID, string $Recipient, string $Subject, string $Body, int $MediaID)
InstanceID | ID of the SMTP instance |
Recipient | Recipient's e-mail address |
Subject | Subject of the email |
Body | Content of the email. Sent as HTML (since 7.0) if <html> and </html> is found, otherwise as text |
MediaID | Media object ID (image/sound and document only) |
Sends an email with the subject, media object and text to recipients via the instance with the ID InstanceID. In contrast to the SMTP_SendMailMedia function, the recipient can be specified explicitly in the function call.
SMTP_SendMailMediaEx(12345, "me@example.com", "Alarm!", "Someone rang the doorbell, but you're not here!", 23456);
