SMTP_SendMailMedia
Require: IP-Symcon >= 4.0
 boolean SMTP_SendMailMedia (int $InstanceID, string $Subject, string $Body, int $MediaID)
ID of the SMTP instance
Subject
Subject of the email
Body
Content of the email. Sent as HTML (since 7.0) if <html> and </html> is found, otherwise as text
MediaID
Media object ID (image/sound and document only)
Sends an email with the subject, media object and text via the instance with the ID InstanceID.
The recipient specified in the properties page will be used. If different recipients are to be addressed, the SMTP_SendMailMediaEx function is to be used.
SMTP_SendMailMedia(12345, "Alarm!", "Someone rang the doorbell, but you're not here!", 23456);
