SMTP_SendMailAttachmentEx
Require: IP-Symcon >= 2.2
boolean SMTP_SendMailAttachmentEx (int $InstanceID, string $Recipient, string $Subject, string $Body, string $FilePath)
InstanceID | ID of the SMTP instance |
Recipient | Recipient's e-mail address |
Subject | Subject of the email |
Body | Content of the email. Sent as HTML (since 7.0) if <html> and </html> is found, otherwise as text |
FilePath | Path to the file |
Sends an email with the subject, attachment and text to recipients via the instance with the ID InstanceID. In contrast to the SMTP_SendMail function, the recipient can be specified explicitly in the function call.
SMTP_SendMailAttachmentEx(12345, "me@example.com", "Alarm!", "The heater is down!", "media/webcam.jpg");
