SMTP_SendMailAttachment
Require: IP-Symcon >= 2.2
 boolean SMTP_SendMailAttachment (int $InstanceID, string $Subject, string $Body, string $FilePath)
ID of the SMTP instance
Subject
Email subject
Body
Content of the email. Sent as HTML (since 7.0) if <html> and </html> is found, otherwise as text
FilePath
Path to the file
Sends an email with the subject, attachment and text via the instance with the ID InstanceID.
The recipient specified in the properties page will be used. If different recipients are to be addressed, the SMTP_SendMailAttachmentEx function should be used.
SMTP_SendMailAttachment(12345, "Alarm!", "The heater is down!", "media/webcam.jpg");
