SZS_CallScene
Require: IP-Symcon >= 5.0
 boolean SZS_CallScene (int $InstanceID, int $SceneNumber)
ID of the Instance
SceneNumber
Number of the Scene
Gets the values of the scene with number SceneNumber stored in the scene control module with InstanceID InstanceID and sets the associated variables.
SZS_CallScene(12345, 1);
