RegVar_SendEvent
Require: IP-Symcon >= 4.1
boolean RegVar_SendEvent (int $InstanceID, int $ReportID, string $Text)
InstanceID | ID of the RegisterVariable-Instance |
ReportID | The record type as ReportID |
Text | Buffer to send |
Sends a string Text through the instance with ID InstanceID as the record type ReportID.
RegVar_SendEvent can only be used with a HID instance
//Send an event “Hello World” to the parent instance with the ReportID 0
RegVar_SendEvent(12345, 0, "Hello World");
