Random Lighting
Require: IP-Symcon >= 5.0
The module allows to switch the color value of lamps randomly between different colors.
function scope
  • Color variables can be added to a list
  • A list of colors can be selected from which can be expanded
  • When the module is deactivated, the selected color variables are set to the value before activation
  • Setting of the interval in which the colors should be changed
software installation
  • Using the Module Store install the 'Random Lighting' module.
Set up instances in IP-Symcon
  • Under 'Add Instance' the 'Random Lighting' module can be found using the quick filter.
Configuration Page:
name description
Color Variables List of color variables to be switched
Colors Colors from which one is randomly selected for switching
Change Interval Interval between each switching in seconds
Simultaneous switching defines if all color variables are set to the same color or to different ones
status variables
Status variables
Name Type Description
Active Boolean Switches the module on or off
