UWZ_RequestInfo
Require: IP-Symcon >= 4.2
 boolean UWZ_RequestInfo (int $InstanceID)
ID of the Instance
Calculates the variable rain value of the rain central module with InstanceID InstanceID.
UWZ_RequestInfo(12345);
