AS_SetSimulation
Require: IP-Symcon >= 5.0
boolean AS_SetSimulation (int $InstanceID, boolean $SetActive)
InstanceID | ID of the presence simulation |
SetActive | Enables/Disables Presence Simulation |
SetActive enables (true) or disables (false) the presence simulation with InstanceID InstanceID.
AS_SetSimulation(12345, true);
