SAM_UpdateCalculations
Require: IP-Symcon >= 5.0
 boolean SAM_UpdateCalculations (int $InstanceID)
ID of the Instance
Calculates all values displayed in the webfront based on the data on the configuration page.
SAM_UpdateCalculations(12345);
